Yet Another LTx HID Projector Thread!
http://www.duplicolor.com/products/metalcast.html
And in this picture, you can see that it barely clears. It may clear a little more once its aimed right.
But yeah if you need a hand with anything let me know, I've pretty much got the vacuum forming down pact now after so much trial and error. I think the easiest thing to do for your shield will be to use the projectors lens as a mold, and form the plexiglass over it. Then just trim it up enough to drop right into the shroud, and silicone it from the inside to hold it into place. Or use JB Weld if you want to be extra cautious.
https://ls1tech.com/forums/appearanc...-write-up.html
The depth should be more like the shrouds on those FX projectors in the images above or like the shroud on the Murano projector below:
The projector's lens should stick out past the shroud.
Glad to see more people are attempting this on their LT1 birds.
http://tinyurl.com/36m7hcb
hope this helps!
