how do i run only fogs?
Old Oct 26, 2009 | 06:59 PM
808_ss's Avatar
Default how do i run only fogs?
wondering if theres a way to run only my fog lights on my 2000 camaro?
as of now i can only run my fogs when my headlights are on.
anybody know how to mod this?
Old Oct 26, 2009 | 07:01 PM
6LITEREATER's Avatar
Do a search for the DRL delete mod. It makes it so that you have full control at the switch so they headlights aren't automatic.
From there you can figure out what wire from the headlights feeds power to the foglight switch and hook it to a pink wire (ignition power) instead...
Old Oct 26, 2009 | 07:43 PM
Havok2's Avatar
i run my fogs only by putting emergency parking break 1 click up.
and i run my fogs.halos.parking lights
Old Oct 26, 2009 | 07:56 PM
pir7tr's Avatar
There is a mod where you use a "U" shaped paper clip and plug it into the light sensor under the dash. This is what I have done.
Old Oct 26, 2009 | 08:15 PM
SparkyJJO's Avatar
Fog lights can't turn on until you have at least the parking lights on. You can leave the headlights off though.
I tend to run parking+fogs when it is dusk out.
Old Oct 27, 2009 | 06:44 AM
00RedMaro's Avatar
if its not dark out and your headlights havent turned on automatically, i know you can turn the light switch to the left of the steering wheel to the middle option which turns on the dash lights in the car, and then you can flip the fog light switch on.
Old Oct 28, 2009 | 08:01 PM
808_ss's Avatar
thanks! so if i mod my auto lights, if im correct. .... ill have full control of my headlights on/off and can run only fogs when im in parking lights mode?
Old Oct 28, 2009 | 08:49 PM
SparkyJJO's Avatar
Correct. That's how mine is set up.
Old Oct 29, 2009 | 05:57 AM
bad_408_vert's Avatar
Thats what I do.
Old Oct 30, 2009 | 06:44 PM
99huggerorangeZ's Avatar
i cut the light sensor wires and spliced them together. was the first thing i did when i bought the car 8 years ago, and skip shift lol
Old Oct 30, 2009 | 09:16 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/2743521-post6.html
https://ls1tech.com/forums/appearanc...hting-faq.html
