Any way to "freshen" up rubber?
Jedi Master
I have a 2002 Camaro that while the paint is in surprisingly good shape for its age, the rubber trim on the outside body has signs of damage from the sun(hard, spots on it, etc)
Is there a product or method to fixing this?
I Wet Sanded the windshield weather stripping - you can use this process for all of the weather stripping. I would not suggest sanding the plastic cowl cover.
First tape off the Weather Stripping:
What it looked like:
I started with a low grit (I believe 500) to get off most of the spots and etc.
After that I then Wet-Sand with 2000 to get it smooth then apply a dressing a couple of times, pull the tape off and here's the final product:
It was easy to do one to two hours to do the windshield.
Weatherstrip should get a good soaking with silicone at leat twice a year. Get the silicone liquid and put it on with a small brush, paste and put it in with a stiff small brush, or if all you can find is a spray - spray it into the cap and then brush it on. Let it soak in and the wipe off the excess, your watherstrip will stay soft for years. After it dries, 303 or water based UV protectant will help prevent sun damage.
+1 for meguires mirror glaze vinyl/rubber cleaner and conditioner
http://www.meguiarsdirect.com/produc...?T1=MEG+RUB+16
i also use mothers back to black
I wouldn't wetsand the T-Top Trim, the plastic cowl cover or the window trim that is next to the door - but the trim around the windshield and rear window is thick enough that the wetsanding won't hurt them.
Just use a quality trim dressing like, 303 aerospace protectant, Jax Wax Super Blue Dressing or even Z-16. The rubber that was wetsanded will soak up the dressing like a sponge so four or five coats can be applied.
I clean all rubber trim with Meguires all-in-one and protect with einszett gummi pflege . Whatever you do use , make sure a) it has a uv protectant and b) it is water based , not silicone based . Silicone base products are the early death of rubber , vinyl and interior plastics . Read your ingredients
