faux CF thread?
^^^ it took me a long time to cut the middle out but it was soo worth it.. it's ******* hilarious to use a carbon fiber laptop mouse hahaha
EDIT:: dopefedz that looks great on the fuse covers .. i think i'm gonna do that too and also the pcm
* as you can see there is a few small bumps on the top right side. a light sanding and polish will smooth that out.
*also the hole for the ring wasn't cutout yet
** btw anyone know how I can restore the lettering on my buttons without replacing the buttons? thanks
For those interested in wrapping your key fob here are the steps
(take apart keyfob with scredriver)
1) place the key fobs back onto a cutout vinyl
2) using a heat gun / blow dryer stretch the vinyl nice and tight over the back of the keyfob and have it hang over the front
3) cut the extra vinyl and using a razorblade tuck the vinyl into the creases (very time consuming. heat definitely mandatory.
4) now get a cutout of the vinyl for the front and press it down, using heat to wrap it tight and to get a small outline of the buttons.
5) using the razor trace the rubber buttons, pull off the cutouts, and tuck the vinyl in the creases around the buttons.
6)stretch the remaining slack in the vinyl into the keyfob side creases, mating with the back vinyl cutout. and try to use the flat side of the razor blade to push out all the airbubbles and folds.
7) poke the hole for the ring w/ the razor, feed the ring in and press against the sides to push the vinyl in the inside.
8) lightly sand the sides if you have any little bumps w/ 1500 or 2000 grit.
9) use some liquid wax and onto a microfiber wipe everything down, especially the sides you just leveled with the sand paper. and voila your done, enjoy.
10) show off to all your friends at the superbowl as the Saints win against the Colts!
Also, I don't know if there's a decent way to put new lettering on the buttons, but I do know there's a website where you can get JUST the buttons for our remotes for something like $6 plus shipping. I don't have a link to the site, but my friend does. I'll post it when I get it.
