faux CF thread?
From the left to the right as follows:
No Clear, 1 coat of spray can clear, 2 coats of spray can clear, 1 coat of PPG automotive clearcoat on a CTS-V emblem i wrapped.
Its a little hard to tell on the CTS-V emblem, but the clear filled in all of the texture and basically made it look one solid color. So i would say using a high quality clear is not an option.
I actually put a 3rd coat on with the spray can clear and it came out even better, and if i decide to use this stuff then thats what ill do.
this is why I like texture di-noc w/ clear over the hydrodipping process,,, hydrodipping will not reflect light and give a real 3D look.
Lotus289- what do you like better clear or not... I want the whole subtle 3d look. I find the dry look like in the manifold above too dry looking.
InsaneAuto86- I would try and clear over your job... it will make the wrinkles look less noticeable im sure if you get enough coats on.... worth a try if you wanted to take it off anyhow.
