Instrument panel ?
I have an 02 z28 that a few needles are broken or mis reading on my instrument panel after new gauge overlay install. I have an extra instrument panel out of a 98 z28. Will everything work fine if I put the 98 in the 02? Someone local told me there was a few small diffrences.
If you run your car to normal operating temp. then pull it apart, you just need to get it to operating temp. again and pop the needles back on. Just make sure you noted (I take pictures) where the needles were before you took them off.
And no, the '98 cluster wont work. 6LE's got one and the swap doesn't work. And his '98 wont run without a cluster, but my '01 will.
