TA vent removal
I just got my aeroforce 2 1/16" gauge in and I wanted to temporarily put it in a vent hole. Went to lowes, got a coupler, got home and tried using a kitchen knife on the top of the vent, pushing downward while pulling on the vent itself (carefully).
after 15 minutes and much egg-handling i still wound up with a cracked vent (the center shaft with the adjusting slider) and a cracked bezel. Im not overly worried about it, cause this vent was missing half a fin before i got the car, but I need some insight here, cause im moving the drivers side vent to this hole to replace it, then the gauge will go on the drivers side. Part of the problem is that my AZ dash has expanded ever so slightly so the bezels are overlapped by the pad, but I need to know the RIGHT way to pull out the vents so when im tiptoeing around that and how fragile these are i dont have to worry about my technique too.
me>
<bezel I broke one and got a set. My fear is scratching the soft dash material when I install the new ones. I still have 3 left inside and want it to get 'em out smoothly.
FORTUNATELY, this is quite helpful that you have one out. Now that one is out you can reach in one vent, and push out the other two vents.
NB: Push out the vent & bezel as a whole assembly.
@matt: havent gotten any yet, but i know there were a bunch on ebay when i was looking for ***** and such.
so now we wait for all those cool doods who already did their gauges, ive seen plenty of install pics.
here is just the bezel. For one thing youll notice some fins around the edges, which also hold it in, and you can see how mine broke. I pushed in a knife, and between the bezel edge getting pushed up and down, and the tab itself being pushed toward the front of the car (trying to get that downward motion on the part that moves) the top and bottom cracked the same way.
and heres how my attempts ended for now (just shoved it in. gauge was gonna go on the drivers vent).. On top of not wanting to explode the other vents (this one really ate ****) the coupler i got wasnt the fernco part everyone else was using (3001-22), so its ID/OD are both too wide (too big for the bezel, the gauge is loose). back to the drawing board.
