Recommend to me a good Powder Coating Starters Kit
I want to try my hand at PCing a few pieces for myself but need a kit to get started with. I have a oven but thats it...somebody please point me in the right way. I would like to some thing like wheels, pulleys, jack stands on so on.
Motorboater
I started to reply but got distracted by the ***** in hlaalu's sig. Let me think here.
Not to be captain obvious but I assume you got an old household oven from somewhere to use for only coating, right? You'd be AMAZED how many dingdongs actually assume they can use the one in their house without killing themselves after they poison their next meal they cook in the thing.
Eastwood just came out with a new hobby gun with dual voltage.
You'll need a way to correctly prep the parts. A wire wheel or sand paper is NOT the correct way to do it, you will end up with all sorts of imperfections due to lack of proper cleaning. You'll need a blast cabinet and a compressor capable of running the cabinet, along with associated items such as in line air filtration both for the cabinet and gun..moisture is your enemy in coating.
You will also need to build some kind of booth with fans and filters and lighting. Shooting powder in an open environment will be fun for about 14 seconds. Powder has the consistency of household dust so it floats very far and thanks to its positive charge as it leaves the gun, sticks to everything little thing within 30 feet.
Using too small of an oven for any given part will cause you problems. People forget about infared/radiant heat. Stuffing a wheel in a household oven will over cure it as it will get hotter than the ambient temp you set the oven at. You will need a good IR gun if you intend to use a small oven, and I would recommend building heat shields around the elements as well. I personally wouldn't coat anything bigger than a small bracket or pulley in an unshielded household size oven.
I could go on forever but there's a few very very basic thoughts for you on the subject.
