Is there any pics of you guys installing the resistor ?? That would help. That's the only thing I'm stuck at....
I don't have any pics, but the way I installed mine was really easy. I just bent the ends of the resistor so they formed a loop on each end, and I was able to "plug" it into the airbag connector under the dash.
Ok cool. I guess once i remove the wheel i can see more less what yall are talkin about. Did u do it under the dash or right where u unplugged the bag?
Hey, did anyone use the NRG hub adapter? If so did you have to modify it as well?
I just emailed them about this and here's what parts they said, it looks like they don't have that problem anymore. It looks like a different piece than what people have used in the past. Can someone confirm?
"You will need a vehicle specific short hub. For your Camaro you will need the SRK-170H
With this short hub you can use any of our Gen 1.0 to 3.0 quick releases. It just depends on the color/style that you prefer. "
Jaxcam02, I can tell you that I have an NRG wheel and bought one of the cheaper $35 adapters on Amazon and I had to shave down the internal ribs of column to make it fit. Also with that short hub, the horn button is too deep for it so you can't hook that up to work and the holes are the wrong offset to try an align the wheel. Mine, with my wheels straight kinda angles to the left about a 1/4" and the wheel is about 2" closer to the dash. Best bet would be to get the NRG adapter if you get one of their wheels, about $98 on Amazon...
Hey thanks for the heads up, I went ahead and nabbed the short hub, quick release and wheel all nrg products so I will post how it goes in the next few weeks.
Did you ever get yours installed? I'm looking for a hub/qr for a momo wheel and was thinking about going with the nrg hub/qr.
I can never decide if I want to do this or go with a g6 steering wheel
Might as well go aftermarket. It's too much work and money to try to keep an airbag wheel. I spent three years contemplating and researching viable airbag wheels and I just gave up and focused on getting the aftermarket wheel I wanted most.
I still have the factory steering wheel in, with controls but i have different HU and no SW control adapter. So i dont really need them just want a change
