My engine bay and engine redo - 98 TA
Can't forget the pilot bearing. And proof it is a 6.0L!
SPEC Stage 2 clutch
All together! I thought I had a picture of it with the stainless longtubes on it, but I guess my camera didn't take it!
AAAAAAAAAAAAAAAAAAAAAAAAND BOOM, in the car!
Now to finish the fuel system, do my wiring, finish the brake system, and some other nickel and dime crap.
Then I dropped it down to see how it looked with the full weight in the front. I'm happy with the stance.
My last coil pack relo bracket got here today too, so going to try and mount that soon and run the plug wires.
And then I learned why you should never plan your fuel system while your k-member is not in the car. I can fix it, just need to see if I can find a 6AN male/male fitting and another 6an female hose end or a 6an male hose end locally tomorrow. I was so close to having the steering done, fuel system done, and a big dent in the wiring. Minor setback, to be expected with a car this custom.
Word of advice, do NOT BUY CHEAP AN FITTINGS! Joel put me on to Fragola fittings, so I bought those for the small section of -6 I made. It literally popped right in and tightened down.
I had bought some cheap -4 fittings earlier for the section to the nitrous controller. I worked for an hour on those damn little things before I finally gave up and bought some Fragola fittings. I figured I could wait a couple more days to save my fingers and my sanity.
I also hooked up all the clutch lines and all and got the driveshaft in.
