tcs relocation?
Old Aug 12, 2010 | 06:03 PM
99ws6ls1's Avatar
Default tcs relocation?
well i just got done doing the wire mod on my trans am and love it but now its time to move the tcs module. only problem is, the plastic tubes that come off of it look way to long to be moved behind the pcm. is there a in depth how-to for this? Thanks
Old Aug 12, 2010 | 08:00 PM
madhatter's Avatar
It was rather easy when I did it to a customers car. Unbolt the bracket from the TCS and it will fit just fine behind the PCM.
Old Aug 13, 2010 | 02:35 AM
BlkBird2000's Avatar
You lose traction control when you move it because it is too short.
Old Aug 13, 2010 | 08:33 AM
BIG_MIKE2005's Avatar
First I have heard this. Could have sworn everyone who did it said it worked just fine after relocating it. Otherwise why relocate, just remove it completely if it wont work after.
Old Aug 13, 2010 | 09:28 AM
Unertl42's Avatar
yeah, I moved mine, and my traction control still works fine
Old Aug 13, 2010 | 12:28 PM
gm02ceta's Avatar
do you have pics of the install?
Old Aug 13, 2010 | 02:01 PM
djfury05's Avatar
no you don't.. you only lose in unless you extend the wires for the electrical switch that plugs into it.. which is 2 wires.. very simple to do.........
It works fine being relocated
Old Aug 13, 2010 | 02:27 PM
Sommer86's Avatar
It's super easy, G. If you swing by Bob's big Boy tonight, I can show you mine and tell you how it's all done.
