DIY Tint
Edit: now that i see your from texas too that will come in handy for ya! I wished i did it while i was there now im in WA and it's not needed as much
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
My friend and I have done 3 F-body's with this tint, 1 Trailblazer, and have 2-3 more in line waiting to be done. It's pre-cut so you can't go wrong. The quality is amazing. It's actually black tint, not some cheap-o blue. And you CAN do the rear window out of 1 piece. It takes a long time, but it can be done. Again, we've done it 3 time's w/ perfect results each time.
Side windows in 20%
Rear hatch in 20%. It's much easier to tint w/ the hatch off.
Painting the dot matrix:
...It's pre-cut so you can't go wrong. The quality is amazing. It's actually black tint, not some cheap-o blue.....
Side windows in 20%
How hard is it to take off the hatch? I want to do the same thing but didn't know the troubles
- I've yet to have any trouble with running 20% all the way around :knocks on wood:
- We put the tint on the outside with the protective film still on it to shape it to the window. It takes about 2 hrs to shape it with a heat gun. Then you peel the backing off and stick it to the inside. I'd NEVER tint the outside.
- The hatch is easy to get off. 4 bolts for the hinges, the 2 struts, and the wire disconnect from under the headliner. You have to drop the rear of the headliner, disconnect the wiring, push it back through the hole in the roof, and it comes right out. And yes, bring a friend, it's VERY heavy.
i have 25% on the sides, 5% on the back. Whats the longest youve used that tint on a vehicle? wonder if it stays black and all that good stuff.
get plenty of light so you can spot bubbles.. AND MAKE SURE TO WORK FROM THE MIDDLE OUT!!!!!!!
And I've been running my tint for a little over a year and it's still nice and black. I really don't see this stuff 'blueing' over time. I guess the eBay seller runs a tint shop and sells just the tint online to us DIY'ers. When people pay $150+ for tinting they mostly likely paying for the labor.
I guess the vinyls a lot more grabby than tint, but youre right youd still have to chase down bubbles to some extent.
