Ddm
Old Nov 21, 2010 | 05:16 PM
99huggerorangeZ's Avatar
Default Ddm
ok guys i got my low beams and fogs 9006(35w)/880(55w) all wired up with relay harness's. the low beams work perfect but when i turn my fogs on they are blowing the 20amp tail lamps fuse on the drivers side dash panel fuse block. any ideas??
Old Nov 21, 2010 | 05:20 PM
9WhiteCamaro9's Avatar
You may either need a bigger fuse or the relay harness DDM sales. But my vote would be the relay harness first though.
Old Nov 21, 2010 | 05:25 PM
already purchased and installed the relay harness(2) for both low beams and fogs,figured it wouldnt hurt to do so and dampen the burden on the stock wiring. i guess i will try a 30 amp fuse and go from there,has anyone else ran into this problem or had to increase the circuit protection amperage? should i put a 30 amp fuse in both the relay harness and the dash panel fuse block?
Old Nov 21, 2010 | 06:18 PM
I'm not gonna say it hasn't happened but I've never heard of that happening. But I would change out the fuses and also check all the wiring that make up the whole HID system and also check all the wiring from the HID's to all the fuses to to make sure nothing is touching something else.
Old Nov 21, 2010 | 07:00 PM
VIP1's Avatar
Copy & Paste Moderator
Don't go with a higher fuse. That is not the problem. There is a short somewhere. A higher fuse will lead to melted wires and possibly a fire.
You need to do some trouble shooting to narrow down what exactly is causing the problem. Try each component separately.
Old Nov 21, 2010 | 07:07 PM
sweetbmxrider's Avatar
something is wired incorrectly or possibly grounding out. the fuse shouldn't be switched out if the stock wire can't handle it. burning your stock wiring up is a bad idea.
Old Nov 21, 2010 | 07:24 PM
ya im sticking with the 20 amp tailight fuse,not going to increase the amperage. i dont feel like installing a new harness.
Old Nov 21, 2010 | 10:28 PM
428 78T/A's Avatar
Still waiting to see a tutorial on how to wire both sets up. Got any links?
Old Nov 21, 2010 | 10:39 PM
http://www.ddmtuning.com/support/ind...1&pcid=0&nav=0
Old Nov 21, 2010 | 10:40 PM
found my problem why my fog lights were powering up.
Old Nov 22, 2010 | 12:24 PM
Danny2tek's Avatar
share for future readers............
Old Nov 23, 2010 | 06:16 AM
https://ls1tech.com/forums/appearanc...r-camaros.html
page #4
Old Nov 23, 2010 | 09:20 AM
SparkyJJO's Avatar
Heck no, NEVER increase the fuse size. That is an extremely dangerous thing to do. Could result in burning down the car from an electrical fire. The original fuse size was selected for a reason.
Please don't suggest such a thing again.
