A/c & heater control panel lights??
Old Nov 27, 2010 | 03:41 AM
Justinktm's Avatar
Default A/c & heater control panel lights??
are there supposed to be lights for the A/c & heater control panel bcuz mine dont light up and also i was wondering what the bulb size was if there are bulbs
Old Nov 27, 2010 | 05:25 AM
9WhiteCamaro9's Avatar
Yeah there is. Are you wanting to replace them with regular bulbs or LED's?
Old Nov 27, 2010 | 06:20 AM
Justinktm's Avatar
Regular bulbs from autozone or oreileys till I get some LEDs
Old Nov 27, 2010 | 09:38 AM
Yeah there suppose to light up but I have no idea what bulb size they are. Maybe they could tell you at the auto parts store or someone on here. Sorry I couldn't be much help but I haven't even messed with the ones on my car to know.
Old Nov 27, 2010 | 03:12 PM
sweetbmxrider's Avatar
on an lt1, there are two bulbs for the hvac. they are size 74. they are the same bulbs that are used for the door panels switch accents.
Old Nov 27, 2010 | 05:15 PM
Justinktm's Avatar
do they look like these?
Old Nov 28, 2010 | 12:34 PM
yes sir, they are a wedge style bulb and are much smaller than your basic 194 like in the side markers.
Old Nov 28, 2010 | 04:21 PM
Ls1CamaroGuy87's Avatar
Might as well get leds while you're at it. Just make sure to get these ones, they are a bit cheaper on ebay:
http://www.superbrightleds.com/cgi-b...2F74-xHP3.html
Old Nov 28, 2010 | 06:24 PM
^ That or the factory ones if you like the dull/off-white looking bulbs.
Old Jul 28, 2013 | 12:02 PM
Big Zeus08's Avatar
how do i pull the bulb out of the socket
Old Jul 28, 2013 | 03:21 PM
sjsingle1's Avatar
grab tight......use a piece of sandpaper if it helps.....i have leds now......used white.....then switched to red.........much better
Old Nov 26, 2014 | 10:06 AM
maroonls1z's Avatar
I was trying to get the bulb out and I broke it! How do I get them out? How do I disconnect the wires to make it easier?
Old Nov 26, 2014 | 10:32 AM
maroonls1z's Avatar
Nevermind, I figured both out. To remover the bulb you MUST remove the wiring connectors first. Use a bent bobby pen and go in through the front where the bulb is to compress the clip holding the wiring in place, then use a small screw driver from the other side to push the bulb out. Hope this helps someone in the future
Old Apr 7, 2015 | 08:58 AM
wvnascar24fan's Avatar
Awesome post. I was wondering how to get the bulbs out. Thanks man.
Old Apr 7, 2015 | 02:48 PM
fbodyrs96's Avatar
Grabbing the bulb with needle nose and pulling it out is even easier.
Old Dec 20, 2015 | 12:41 AM
Warewolf's Avatar
My lights have gone out as well. Can someone please tell me how to access them to change them out?
Old Jan 23, 2016 | 12:33 PM
Warewolf's Avatar
I tried pulling out the HVAC panel from the front, but it won't pull out far enough for me to access anything. It seems as if there is a thick black cable on the lower right that does not seem long enough to let me pull it out. Any help would be appreciated!
Old Feb 13, 2016 | 11:04 PM
johnny6's Avatar
There's no reason to pull out the whole panel, you should be able to pull it out enough to disconnect the bulbs. I just did this today in my Z, ordered a trans am hvac control module and used my ***** from the Z. Went with red led's #74
Also went with a TA cluster, got really lucky and found one with almost the same mileage as my stock, also did LED's
Crappy cell phone pics, looks way better in person and it's actually red not orange
Old Feb 14, 2016 | 02:10 AM
Warewolf's Avatar
I'll have to try again, but I couldn't even get it out far enough to get my hand behind it to disconnect anything.
Old Feb 14, 2016 | 06:06 PM
johnny6's Avatar
Just a warning and some tips, make sure the temp control **** is either at the coldest or hottest setting that way it's easy to line up when you reinstall it. It has two clips that hold the temp assembly in place, the vacuum line harness also has two tabs, one on the top right and one on the bottom left, gotta be real gentle and careful with that one. The other connections are fairly easy, good luck.
