LEDs in cluster
Old Jan 5, 2011 | 02:57 AM
slow93z's Avatar
Default LEDs in cluster
iv seen people do the LED color change or the ls1 style gauge clusters. just wondering if its possible to do this in the lt1 camaro gauge clusters. id like to put blue LEDs in. anyone know if you can do it?
Old Jan 5, 2011 | 10:28 AM
beyonddisturbed's Avatar
try the search bar broski
Old Jan 5, 2011 | 10:29 AM
Camaro34657's Avatar
Good question. I only ever see LS style ones changed out. I'm sure you can though.
Old Jan 5, 2011 | 12:35 PM
ssteven's Avatar
Pull your gauge cluster out and look behind it for the bulbs.
Old Jan 5, 2011 | 10:27 PM
slow93z's Avatar
yea i have taken out the bulbs before but didnt know how to replace them with LEDs. anyone know how this is done?
Old Jan 5, 2011 | 11:41 PM
9WhiteCamaro9's Avatar
Yes you can. Do a search for Bulb to LED list and it will give you both listings for LT and LS gauge clusters.
Old Jan 6, 2011 | 01:37 AM
slow93z's Avatar
cool thanks alot.
Old Jan 6, 2011 | 11:05 AM
sweetbmxrider's Avatar
http://www.njfboa.org/forums/showthr...+gauge+cluster
post 35 breaks it down. toughest part is the cluster bulbs have the filament ends pulled through the bottom of the socket then up the outside where its soldered lightly. makes for a fun day of little wire nonsense.
Old Jan 7, 2011 | 11:27 PM
slow93z's Avatar
so do the LEDs plug right in or do you have to do some modifications?
Old Jan 8, 2011 | 07:16 AM
^ I have no idea about the LT's gauges. On LS's, everything is plug and play except for the radio and odometer lights. Someone correct me if I'm wrong since I've not done mine to know yet.
Old Jan 8, 2011 | 10:08 AM
For the odometer you have to solder the bulbs in. Don't know about the radio.
Old Jan 8, 2011 | 07:36 PM
slow93z's Avatar
gotcha, well i guess il just figure it out when i try it
Old Jan 9, 2011 | 10:33 AM
You have to straighten the leads so you can push them out the bottom of the socket then bend them up onto the contacts. You will see what I mean when you take one out. Test each one as you go or test it before you put it back together.
