Sponsored by: DashLynx
How did they hide this harness? PICS INSIDE
Old 06-11-2011, 12:59 PM
RedVertTA's Avatar
Default How did they hide this harness? PICS INSIDE
How did they hide the wiring harness? I don't see connectors to the injectors or the coil packs.
Stock:
After:
By the way does anyone know what kind of fuel rail that is? Its beautiful.
Old 06-11-2011, 01:07 PM
ANTICOP RAM AIR's Avatar
the harness is under the intake cap, it has fillers on the edges where it makes contact with the heads... then they run it down the back and tuck it up under the firewall.. that is one of the besst examples i have seen.. that is one dope *** wire tuck...
Old 06-11-2011, 01:10 PM
also, it may have been touched up.. photoshop is awesome nowadays..
Old 07-04-2011, 02:43 PM
RedVertTA's Avatar
Bump. Anyone else have any more input to share?
Old 07-04-2011, 03:21 PM
KILLER-LS1's Avatar
is that the MSD Ignition cadillac CTS-V? If so, I can find out anything you need to know. I know the guys who built that car
Old 07-04-2011, 03:43 PM
RedVertTA's Avatar
Yes it is.
Old 07-04-2011, 04:48 PM
KILLER-LS1's Avatar
ill see what I can find out this week.
Old 07-04-2011, 04:58 PM
RedVertTA's Avatar
Thanks.
Old 07-04-2011, 06:16 PM
The Dragon's Avatar
I'd like to know as well.
I got rid of those coil packs a couple years ago. Since one of the guys in this thread is friends with the MSD co. I won't speak on the reasons.
Old 07-05-2011, 01:08 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'd like to see how they did it as well.
Old 07-08-2011, 03:10 PM
PAGregSS's Avatar
I think your first reply nailed it. It has a carbon fiber look cover over the actual intake and all the wiring is under that cover. It's likely they separated the wiring for the coil packs and the injectors. The wiring for the coil packs are probably under the coil pack brackets while the injector wiring is under the cover. Not hard to do, just time consuming to remove the wire loom and pick out the appropriate wires and separate them.
If you look closely, you can see the wiring for the throttle body coming out from under the intake cover.
Quick Reply: How did they hide this harness? PICS INSIDE
