٩(●̮̮̃•̃)۶ How to Carbon Fiber wrap berger panel with Pics. ٩(●̮̮̃•̃)۶
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Yes my panel was shaved before, did the letters and key hole. Also the hatch isn't closed so the gap is big as you see.
Before
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0012.jpg)
After
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0106.jpg)
Steps
Spray both the sticky side of the vinyl and the surface with a diluted soap and water mixture, then lay the vinyl on top and position.
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0100.jpg)
Start to push the water out from under near using a squuege or something similar
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0101.jpg)
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0099.jpg)
Trim excess material
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0102.jpg)
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0103.jpg)
Use heat gun or hair dyer to heat the entire wrap and wrap the edges and get rid of any bubles that may be trapped.
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0104.jpg)
Final product
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0108.jpg)
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0107.jpg)
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0105.jpg)
Also did the emblem and triangle things
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0111.jpg)
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0110.jpg)
Before
After
Steps
Final product
![](http://i19.photobucket.com/albums/b160/2fast4urass/IMG_0109.jpg)
Also this is the "dry" look.
