How to Remove TA Round Air Vent's??
Old Aug 9, 2011 | 12:58 PM
89ROC-Z's Avatar
Default How to Remove TA Round Air Vent's??
Got 2 5/8 boost and fuel pressure gauges to put in the TA, but i can't get the vents out...and i don't want to break anything. What's the easiest way to do this?
Old Aug 9, 2011 | 01:16 PM
ZexGX's Avatar
https://ls1tech.com/forums/appearanc...-98-02-ta.html
https://ls1tech.com/forums/appearanc...t-removal.html
Old Aug 9, 2011 | 01:35 PM
optiplex's Avatar
they should just "pop" out. IIRC it took a little effort the first time but after that they came out pretty easily...just grab ahold of the vent, wiggle it a little and pull at the same time...
Old Aug 9, 2011 | 04:36 PM
89ROC-Z's Avatar
So i not only take out the vent/air thing, but i also take out the bezel surrounding that?
Old Aug 9, 2011 | 04:39 PM
optiplex's Avatar
yeah, the bezel will come out as well, and the 2 5/8 gauges will fit perfectly
Old Aug 9, 2011 | 05:32 PM
Cheetoh's Avatar
I have a TA also, Is the Vent on the Left end of the Dash the same as the 3 middle ones?
Old Aug 9, 2011 | 05:48 PM
optiplex's Avatar
yeah, all the round vents are the same...
Old Aug 9, 2011 | 06:02 PM
stroked383HSR's Avatar
use the smallest flatest screwdriver to help you carefully pry it out of the socket.
that's what i did.
Old Aug 9, 2011 | 06:50 PM
TransWS6Am's Avatar
good luck, they break easy.
Old Aug 9, 2011 | 06:55 PM
SparkyJJO's Avatar
Vent's? The vent's what?
/grammar ****
Old Aug 9, 2011 | 07:33 PM
TransWS6Am's Avatar
no actually they are not all the same. The 3 center vents are the same, but the other 2 are different.
Old Aug 9, 2011 | 07:36 PM
Danny2tek's Avatar
^ Damn beat me to it
Old Aug 9, 2011 | 07:57 PM
Cheetoh's Avatar
Do they all remove the same way?
