Ask a Professional Detailer
Old Apr 20, 2013 | 01:05 PM
  #2181
zed28camaro's Avatar
well I finally got a GG DA and put it to the test on my camaro today. Need some advice though. I used a uber 5.5 yellow pad with 105 for 2 passes on 4. Swirls were removed to my liking. Then 1 pass with 205 on the uber green pad at 4. Now I almost have what looks like holograms on my hood. Was my yellow pad too aggressive and the 205 cant quite finish down to that? Should I try the green pad with 105 then my 205 on their blue pad? Girlfriend wants me to detail her GTO already today too. Any suggestions would be appreciated. Thanks!
Old Apr 20, 2013 | 03:21 PM
  #2182
LilJayV10's Avatar
A D/A polisher by design won't leave holograms like a rotary. However the D/A can leave micromarring(which is from the pad and/or compound being too aggressive) I would suggest taping off a section 1x1 or 2x2 and try different pad combinations to see exactly what's causing it. Can you snap a few pics so we can see what you are seeing? That will help a lot.
J
Old Apr 20, 2013 | 05:57 PM
  #2183
AWDTBSS's Avatar
Try the blue pad, the green pad is a light cut/polishing pad so I wouldn't finish down with a green. The blue is strictly polishing. If that doesn't work get a black as that is a finishing pad.
Old Apr 20, 2013 | 10:06 PM
  #2184
GoFast908Z's Avatar
You may want to drop the speed down to 3 as well.
Old Apr 21, 2013 | 07:51 PM
  #2185
Adam's Polishes's Avatar
Well since Autogeek and Adam's both had great sales today I picked up some stuff I've been wanting for a while now.
From Adam's I got;
Wheel cleaner(thanks Nick!)
VRT
The new Total Interior Detailer
Various applicators
various bottles, sprayers
From AG last weekend;
Pinnacle Glass cleaner
Pinnacle Water spot remover
Sonax
Pinnacle Ultra Poly Clay
From AG tonight
LC CCS thin green pads
LC CCS thin red pads
LC Hydro tech tangerine pads
FG 400
PF2500
SF4000
Going to restock on some Iron-X from Car Pro and try their Quartz Dlux plastic and rubber coating.
I will also probably get some MF towels from Microfibertech. I need some glass towels and I want to pick up their cobra junior yellow towels.
This should pretty much cover whatever future jobs will bring.
I am going to do a head to head against Sonax and Adams Wheel cleaner soon. I will post my results.
Thanks for your order! Can't wait to see your results from the wheel cleaner matchup!
Old Apr 21, 2013 | 09:01 PM
  #2186
Seems that cleaning the pad out more frequently and dropping the speed worked well. Ill edit this with my a picture of my results. Thanks for the advice
Old Apr 22, 2013 | 09:34 AM
  #2187
92SilverSHO's Avatar
Is 3 for polishing? What are you using for swirls? 5, i find anything higher i can barely hold on the damn thing its vibrating to much.
Old Apr 22, 2013 | 07:47 PM
  #2188
Tomkat3012's Avatar
Default Rust removal/Repair
There are rust spots on both sides of my car on the fender well (I believe). Does anyone know how to remove and or repair these types of rust spots. I went and got an estimate today at a collision shop and it was extra steep at $840.
http://
Old Apr 22, 2013 | 10:36 PM
  #2189
LilJayV10's Avatar
http://
This will be better answered in the paint and body forum. That type of repair is out of the realm of detailing/paint correction. Good auto body work is like good paint correction work, it's not cheap to do it right.
Old Apr 22, 2013 | 10:43 PM
  #2190
Tomkat3012's Avatar
ok thanx, I will repost it there
Old Apr 23, 2013 | 01:45 PM
  #2191
02BlackBullet's Avatar
You didn't go too aggressive with the compound. You just forgot a step in between the yellow/ 105 and the green. I personally would use yellow/105 if the swirls are really deep/bad then a follow up of orange/105 and then finish off with 205/white pad before sealing/waxing. You've done the hard part. Just forgot a step. Do the 105/orange then 205/white and not only will you 86 the marring leftover but you'll also pick up a good amount of gloss. Also, increase your speed. I use setting 6 on my Flex for compounding/polishing for the most part. Works better with more heat. Also, lighten up at then end of your buffing each panel. 105/101/205 are all micro abrasives which finish down finer with less pressure. Prevents over hazing but if cutting deep, you generally will have some to a certain extent.
Old Apr 27, 2013 | 08:29 PM
  #2192
Rare96LT1Formula's Avatar
Just scored a 5L jug of Sonax for $60! 5L jug of 1Z cockpit for $48. Grabbed a 32oz bottle of M101 for $32. Three pack of low profile hydrotech pads for $14. Five piece Raceglaze brush set for $20. I have found some ridiculous deals lately that have allowed me to finally restock for the spring/summer.
Jeff/Jason - Seriously, have you guys discovered detailersclub.com yet?
PM me, I have a discount code for new members. Sorry if I sound like a hyped up internet saleman, it's just that I typically spend a ton of money on detailing gear so this site has cut my monthly detailing expenses by almost 40%.
Old Apr 29, 2013 | 02:30 AM
  #2193
LilJayV10's Avatar
Here's my review on the wheel cleaner. I thought I would post a link because its too much to post in here.
https://ls1tech.com/forums/appearanc...ct-review.html
Old Apr 29, 2013 | 06:31 PM
  #2194
LilJayV10's Avatar
Has anyone used Buff & Shine's new MF pads? I have heard a lot of good things about their foam pads. I'm pretty sure HD's pads are B&S.
I was going to pick up some HD products but Jeff suggested some Menz products. One HD product I'm really interested in is the HD Polish. From what I've read on Autopia its comparable to the Menz 85RD but wipes off a lot easier.
Old Apr 29, 2013 | 11:38 PM
  #2195
AWDTBSS's Avatar
HDs pads are buff and shine, I still need to get some B&S MF pads to try but I saw that someone said the cut isn't as good as Meguiars MF pads
Old Apr 30, 2013 | 10:21 PM
  #2196
LilJayV10's Avatar
Have you seen the video Barry did showing some new top secret product that he described as "not a polish...not a compound..."?
I don't know how hard the paint he was working on but it seem similar to FG400.
Old Apr 30, 2013 | 10:58 PM
  #2197
AWDTBSS's Avatar
Ya I have seen that, it worked pretty good. Not sure when its coming out tho, want to try some myself
Old May 1, 2013 | 10:24 PM
  #2198
Screamin_99's Avatar
Anyone use a steam cleaner in their lineup? I was looking at a few models and some of them are upwards of 700-1300 dollars.
I don't want to drop that kind of coin for one.
Anyone have one they use with good results that isn't an arm and a leg? I've been pretty impressed with some of the videos I've seen on the net with the cleaning of some of them.
Old May 2, 2013 | 10:08 AM
  #2199
Are you a professional detailer or a hobbyist?
I recently purchased a dupray hill injection unit and it was easily one of the best investments I've made. I know some units such as the Mytee Firebird and Vapamore Primo are well reviewed and in a more affordable $300ish price range. I'm glad that you brought this question up as I've been meaning to chat with Jeff & Jason regarding steam usage.
Old May 2, 2013 | 06:32 PM
  #2200
More of a hobbyist myself, but I would like to start detailing on the side for a little extra cash. Just have not been able to build a client list to go to a more professional status
