Ask a Professional Detailer
GoFast- You have any experience with Optimum No Rinse?
I use it all the time... And coincidentally I use 2 home depot buckets with grit guards and a Cobra Chenille microfiber wash mitt.
Directions:
Add 1 oz. of Optimum No Rinse™ Wash & Shine to 2 gallons of water in a bucket. Soak a plush microfiber towel into the wash solution and wash one section at a time till it is completely clean. Dry the section using a clean plush microfiber towel.
Some people also go as far as filling a lawncare spray pump such as this and spray the car down with the mixed solution and then follow the directions. I guess it gives the ONR time to dwell and loosen the dirt.
I also use ONR as clay lube because it works very well and I can do a ton of cars out of one bottle.
Directions:
This is not a traditional wash replacement. But to be used in case you do not have access to water etc.
- If the car were REALLY dirty, would a quick rinse at the do it yourself place, followed by a parking lot cleaning with the Optimum No Rinse be acceptable as a "traditional wash replacement?" I can see how, if a car were really dirty, the likelihood of dragging dirt across my paint would go up alot.
- Can this Optimum No Rinse REALLY cause no scratching? They say it won't in their writeup...just seems like without knocking solid dirt loose before wiping on the car would have to cause scratches. Then again, I know pretty much nothing about washing and detailing cars, and if you guys use it and say it works without scratching, I'm going to order it and try it this weekend. Would save me $7 a weekend if it works.
Directions:
http://www.youtube.com/watch?v=mYOAyxsEIuQ
I've got a few questions that I did not see asked...maybe because they are stupid...
1. I imagine there has to be other folks on this forum that have to wash their car at a self service auto wash place...any thoughts on how to make this work? Right now, I'm using the low pressure rinse, then the soapy brush, then the low pressure rinse, driving home, using a microfiber towel to get whatever water hasn't blown off, then using a detail spray on the whole car...am I committing a bunch of cardinal sins?
2. I didn't see any mention of those silicon "t" edge water blades for drying a car...is that because they are just awful to use?
3. Do you offer any kind of consultation service? Maybe someone sends you some cash through paypal and you give them a half hour telephone consultation so that they can come up with a good solution for keeping their car looking good without having to become a master detailer? If so, pm me because I'd like to do that.
2. I don't recommend them. Get 1 spec of dirt and they will scratch your paint badly.
3. PM sent.
Yes, I use it as clay lube all the time and as my main detail spray because of the awesome lubricity it has. When running water isn't available I will use it. Revolutionary product.
Did this car on the Stanford Campus with ONR since there was no water available.
http://www.autopia.org/forum/click-b...-cayman-s.html
Directions:
Both these guys are dead on right. Well said.
Any chance something like this can be "fixed" by an experienced detailer?
https://ls1tech.com/forums/paint-bod...de-swiped.html
I wouldn't dare attempt it myself, but since I cant afford paint, I figured I'd see if I have any other options.
