Ask a Professional Detailer
Old Feb 25, 2012 | 08:03 AM
  #981
JUSTINSWS6's Avatar
Update i used m105 and m205 by hand it looks awsome. The weather striping did not have swirls i thought it did. It did have water spots and a little discoloring. Used a clay bar and it cam out and looks new thanks everyone. Also what is the best way to polish stainless steel?
Old Feb 25, 2012 | 08:08 AM
  #982
Junkman2008's Avatar
Originally Posted by JUSTINSWS6
... Also what is the best way to polish stainless steel?
A Mother's Powerball and the aluminum polish of your choice.
Old Feb 25, 2012 | 08:47 AM
  #983
SleeperD's Avatar
Mothers Mag and Aluminum polish, and #0000 steel wool
Old Feb 25, 2012 | 08:50 AM
  #984
Polishing aluminum wheels by hand is for people doing prison time. If you want to get done sometime today, the Powerball is the way to go.
Old Feb 25, 2012 | 08:58 AM
  #985
JUSTINSWS6's Avatar
Thanks mothers mag and aluminum worked very well!
Old Feb 25, 2012 | 11:18 AM
  #986
GoFast908Z's Avatar
I actually would not recommend the steel wool any longer. Just use a microfiber (never one that will be used on the paint) and take your time.
Old Feb 25, 2012 | 11:24 AM
  #987
JUSTINSWS6's Avatar
Didnt you use steel wool on your vette exhaust? I heard from the old timers not to use it on stainless because steel rust and some of the steel will be left on the stainless causing rust spots.
Old Feb 25, 2012 | 11:30 AM
  #988
GoFast908Z's Avatar
Yes I did, but I'm not using it any longer. After some discussion and research I've decided to stick with the softer MF towels. Yes it takes longer but the outcome is better.
I think the old timers need their eyes checked....if there are rust spots then they never wiped the residue off completely, or their chrome is pitted and will rust regardless.
Old Feb 25, 2012 | 11:38 AM
  #989
JUSTINSWS6's Avatar
Yeah they never tried it just saw people do it then month later it rust... But most people dont wipe it off well enough. I used the cone thing mcguiers has and it came out great. Really reflects
Old Feb 25, 2012 | 12:44 PM
  #990
That's exactly why I use the Powerball. I'm too damn old to be rubbing my ball and socket joints into oblivion. I would hurt for 3 months if I tried that crap now.
Old Feb 26, 2012 | 09:12 AM
  #991
BadCompany VP WS6's Avatar
Originally Posted by Junkman2008
That's what POLISHING does. Polishing stuff makes it shine. That's true with jewelry, leather, glass, aluminum, diamonds and plastic.
I wouldn't start with M105 on plastic until I tried something less abrasive first. The correct product coupled with an effective technique eliminates the necessity to get aggressive when correcting something.
This has me baffled. You have swirls in the rubber trim??? Post a high quality picture. This I have to see.
You're absolutely right about taking the least aggressive approach first. However, 3 combinations in to trying to correct it and it didn't put a dent in it. They were HEAVILY oxidized and I simply posted the method I took. But, everyone should take that approach for everything.
Old Feb 26, 2012 | 09:14 AM
  #992
JUSTINSWS6's Avatar
Like i said i did it by hand mine where.not super bad... I just had to push hard
Old Feb 26, 2012 | 09:39 AM
  #993
Originally Posted by BadCompany VP WS6
... However, 3 combinations in to trying to correct it and it didn't put a dent in it.
I must have totally missed the part where this was stated.
Old Feb 26, 2012 | 02:27 PM
  #994
cam kidd's Avatar
Originally Posted by My6speedZ
Usually yes, you only need heavier compound if your trying to get scratches out.
is the only and best way to get scratches out is a buff? I have a black ws.6 and it may need one soon to get some of the small scratches out
Old Feb 26, 2012 | 02:37 PM
  #995
JUSTINSWS6's Avatar
If it is really light you can do it by hand. Pics will help. If you have a porter cable 7424xp get 105 and 205 use white pad with 105 and black bad with 205.
Old Feb 26, 2012 | 03:09 PM
  #996
You need to understand what a scratch is, where it is located and what you have to do in order to remove it. What I will explain to you is the method to REMOVE the scratch.
First off, imagine a flat section of your finish as perfect and blemish free. If you were to cut a slice of it away and look at it at eye level, it would be as straight as a razor's edge. Now imagine a scratch has surfaced. At eye level, this is what you would be looking at:
Now you have two option that you can use to REPAIR this damage. You can repaint the area, which would be silly to do if the scratch is minor. Or, you can cut away some of the clear coat, and make it level BELOW the point of the scratch. At that point, your clear coat is perfect again and the scratch has been removed.
In order to shave the bad clear coat away, you have to use a POLISH. It, along with the use of a polisher allows you to shave clear coat off the car. Different polishes will cut different amounts of clear off the car so it is imperative that you use the correct polish for the job at hand. Knowing what polish to use comes with experience. Using a polisher is MUCH faster than trying to do it by hand. MUCH FASTER.
So does that make sense as to how a scratch is repaired and why a polisher is the preferred method?
Old Feb 26, 2012 | 03:11 PM
  #997
What brand pads are you talking about? The colors are not the same with all manufactures. Orange is mostly used for medium scratches and thus would be used with Meguiar's M105. White would be used with Meguiar's M205.
Old Feb 26, 2012 | 05:59 PM
  #998
JUSTINSWS6's Avatar
I forgot brand got it from autogeek i think wolf something.
Old Feb 26, 2012 | 06:19 PM
  #999
Wolfgang. They use the industry standard pad colors too. Black is or applying waxes, glazes and sealants. You would use their orange and white pads as I described in my earlier post.
Old Feb 26, 2012 | 06:52 PM
  #1000
JUSTINSWS6's Avatar
O well these pads where for what i used and came with orange pads if it was really bad. Car came out great atleast. I swear they are mcguiars or wolfgang could be wrong.
