Ask a Professional Detailer
Very true. Sal's terminology is slightly different from the industry norm.
I searched "silver" and "sebring" within this thread and didn't come up with anything helpful.
For a nice 'nuba, P21S 100% looks REALLY good on silver. If you can find it....I'd get Megs #16, but good luck finding it.
Nobody? ...local guys and friends of mine say to try goo-gone. Has anyone used it on a dash before?
. i will say that i had great results without damaging the dash. The Best V8 Stories One Small Block at Time
I guess my questions is, will the rotary be fine? Or should I really invest in a PC?
http://www.griotsgarage.com/text/con...l_why-use.html
By the way, if you purchase those polishers with a kit, that makes them significantly cheaper. If anyone needs a coupon code, I can get you one for Adam's. Just PM me, I'm not going to post it in this thread. I do give it out near the end of any video series that I have done.
Orbital polishers and dual action polishers are two different things. A dual action polisher (like the Flex3401-VRG), is significantly more powerful than any orbital polisher and will be rated in OPM's & RPM's. The polisher you're talking about is only a orbital polisher (rated in only OPM's) and thus, performs similar to the Meguiar's polisher as well as the PC. Thus, there is no advantage of one over the other except for cost. You can't call a orbital polisher more powerful than another unless the OPM's are significantly higher than the other. For example, those cheap, China made orbital polisher in the auto stores have a max output of 3000 OPM's. The PC, Griots and Meguiar's machines get up in the neighborhood of around 6800 OPM's. That's significant.
The OPM difference between the PC7424XP and the older PC-7424 is 800 OPM's. I have both. Used side by side, you cannot tell the difference between either and the newer one does no more faster correcting than the older one. Eight hundred OPM's is not a significant difference. Thirty-eight hundred is. Thus, all three machines that I have mentioned are equal in performance.
Look at it as horsepower. It's that power that gets to the wheels that matters.
