Ask a Professional Detailer
As far as compounds go I would start with M205 and see what that does. The only way to know for sure is to do a test spot.
If you are asking these basic questions my suggestion is read this thread several times. All of these things have been covered.
I do have the wiper scape mark on mine and it's way too deep to buff out without distorting the glass a lot. So I've left most of it alone.
That Eastwood kit is close to what I use on finer scratches in windshields (laminated glass). On tempered door glass that kit won't beable to cut hard enough to do anything though.
Cleaning them up is about the same. I started using Dawn Power Dissolver. I have used Meg's APC, Simple Green and some Pinnacle stuff and like the Dawn the best. It's pretty popular on Autopia too.
The Meg's MF are machine washable. I tried them in the washing machine a few times but they didn't come that clean. Now I shoot them with the Dawn PD and let them sit 5-10 minutes then rinse them out by hand under hot/warm water. After I squeeze them out I throw them in the dryer.
With the MF pads or the foam pads for that matter I use the cleaning brush to knock off most of the heavy stuff before I wash them, it makes cleaning them a lot easier.
MF pads and M105 is an awesome combo and can do some serious correction. The hood on the Camaro I'm doing needs wet sanded. I think I am going to get some Surbuf pads and test them out.
J
I'd wash them before use, it shedded like crazy lol
You can actually take it off very quickly by machine. Very thin single stage paint.
The differences with the MF pads from what I have found and talking to Jeff is you use a little more pressure than the foam. You use a little more product when priming the pad but don't add as much as you go.
J
I really enjoy these new LC MF pads, but the price is brutal!! Wish these were a little cheaper but I'm always happy to pay for quality, and thats what these are.
The surbuf pads cut like hell but finish like crap in my experiences with them. It doesn't really matter to me at least, because when you need a pad as aggressive as the surbuf is, you're going to have to finish down either way. I will say this though, everytime I have used a surbuf, I have had to do a three step on each vehicle. All of them finished fantastic though, just needed the extra polishing step.
My car has a slight musty odor to it. I did have a small window leak which lead some water to sit behind the drivers seat. The window was adjusted and all is good as far as sealing. This was about a year ago.
Is there any way to get rid of that smell? I've tried baking soda boxes, dryer sheets, air fresheners, etc. The only other option I can think of is deep cleaning the carpets and allowing them to dry thoroughly.
Thanks
Thanks
Thanks
Cleaning out the interior, then closing it up won't eliminate the odors.
Like mentioned above, pull your interior, spray the backside of the carpet with a mild bleach spray, then leave it in the sun for the day to completely dry. Then re-install a few days later in your car.
