Ask a Professional Detailer
Old Jul 8, 2012 | 08:38 PM
  #1621
BlueBird346's Avatar
Originally Posted by GoFast908Z
I think the BFWD has it by the looks and the slickness as well as ease of application and removal.
However, Zaino gives a much better reflective surface and will beat the durability of BFWD by almost double (3-4mo vs 6+ mo)
Ok thanks. I think I'll stick with my Zaino.
Also, I need some info on compounding. Not every car needs to be compounded right? If not, how can I determine if mine needs it?
Im doing a full detail on the car soon. Im going to use Mezerna SIP. Id just like to know what to do before that, aside from the typical washes, clay, ect.
Sorry if this has already been covered, 81 pages is a lot to read through.
Old Jul 8, 2012 | 09:44 PM
  #1622
Blkdvll's Avatar
Just because it's a process you don't use, or maybe aren't familiar with, doesn't make it the wrong way.
Old Jul 8, 2012 | 10:38 PM
  #1623
dabest09's Avatar
After claying, if the car isn't being compounded or polished do you still do an IPA wipedown? It seems like clay lube leaves residue on the paint that would effect bonding of the sealant.
Old Jul 9, 2012 | 12:09 AM
  #1624
mac62989's Avatar
Going to the local stores for Tarminator tomorrow. Thanks for the tips.
Old Jul 9, 2012 | 07:50 AM
  #1625
Drokkers's Avatar
so does it go, foam wash,clay bar,compound,polish, then seal it? set me straight if im wrong
Old Jul 9, 2012 | 12:08 PM
  #1626
mac62989's Avatar
^Correct. Seal or wax last..
Old Jul 9, 2012 | 02:14 PM
  #1627
GoFast908Z's Avatar
You got it!
Old Jul 9, 2012 | 03:59 PM
  #1628
Rare96LT1Formula's Avatar
Jeff -
Wetsanding key scratches out of vertical panels...
Friend with a 2012 Subaru Legacy has two key scratches (on of them finger nail catches, the other it barely catches). I don't want to wetsand them if I don't have to, but I have a feeling it will definitely be needed. I have on hand some meguiars 2000, 2500, and 3000 unigrit sand paper. Is it safe to start with 2000 and work my way up to 3000 then compound with some M105? The car has a metallic paint so I'm not sure if I'd be better off grabbing some touch up paint and filling the scratches, letting them cure, then wetsand afterwards. I can probably get pictures if needed.
Old Jul 9, 2012 | 06:40 PM
  #1629
GoFast908Z's Avatar
Originally Posted by Rare96LT1Formula
Jeff -
Try and carefully fill it in. The wetsanding may remove the fresh touchup but worth a try.... Give it a shot
Old Jul 9, 2012 | 07:02 PM
  #1630
2002ss335's Avatar
I see alot of members talking about purchasing a Porter Cable and wanted to pass along a great deal I recently found. It's $94.50 for the Griots Garage polisher which includes a backing plate. Overall, the Griots is a more powerful unit than the PC and has a much more quiet motor. I own both, but if I were able to start over, I would have ordered the Griots.
http://www.bjs.com/webapp/wcs/stores...7&sc_cid=affil
Great deal and a fantastic unit.
It is on sale now for $89.99 with free shipping. I just ordered one.
Todd
Old Jul 9, 2012 | 07:23 PM
  #1631
GoFast908Z's Avatar
Todd
There is a non-member surcharge....how much was that?
Old Jul 9, 2012 | 07:36 PM
  #1632
2002ss335's Avatar
The site says 5%, but my order went through without any surcharge being added. I did have to pay sales tax because they have stores in Ohio.
Subtotal: $89.99
Tax: $6.30
Shipping: $0.00
Instant Savings: ($0.00)
Non-Member Surcharge (0%): $0.00
Total $96.29
Todd
Old Jul 9, 2012 | 07:54 PM
  #1633
2002ss335's Avatar
GoFast I saw your post recommending the Lake flat pads and wondered why you like them over the CCS and Kompressor pads.
Todd
Old Jul 9, 2012 | 07:59 PM
  #1634
GoFast908Z's Avatar
Todd
They load up with product moreso than the flat pads. I don't like the Kompressors except for applying sealant with a red or gold one via the DA.
Better working time with flat pads for me.
Old Jul 9, 2012 | 08:03 PM
  #1635
2002ss335's Avatar
Thanks I will order the 6-pack pads and a 5" backing plate next.
Todd
Old Jul 9, 2012 | 08:30 PM
  #1636
gs462's Avatar
I read quite a few pages and didnt see the answer i was looking for. Sorry if this is a reask, but My dash the padded part, is gettin dry n fading slightly is there anything I can put on it to slow down or help reverse the damage??
Old Jul 10, 2012 | 01:08 AM
  #1637
chadroosa's Avatar
i have one as well... i was talking to a local detail guy and he said that after he washes a car, rinses it off and leaves it wet, gets new soapy water and uses the soapy water to claybar the car...he says it saves time... have you heard of this and will it work about the same as using the spray..
Old Jul 10, 2012 | 10:31 AM
  #1638
mac62989's Avatar
Well I couldnt find Tarminator at only store locally, tried Advanced Auto and Pep Boys. Jeff, if it is clear coat damage which I think it is, repaints the only option I assume? Is it typical for wax to mask this? I really never noticed it to the severity until after I did a dawn wash. Its almost like I burned through the paint with a rotary when Im only using a Griots 6"..
Old Jul 10, 2012 | 03:11 PM
  #1639
Conrad's Avatar
You don't want the soap and water to dry on your paint, so I wouldn't recommend it. Buy a claybar kit that comes with the detail spray.
Old Jul 10, 2012 | 03:46 PM
  #1640
chadroosa's Avatar
i do cvlay bar with spray, he just says it saves time, he puts soapy water on a panel and clays the panel adding water when needed, and when he is done with the panel he rinses it off then moves to the next, doesnt leave it to dry
