Found a LED flasher that works and is cheap
http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWAX%3AIT
http://www.ebay.com/itm/Grote-Wiring...#ht_1450wt_804
I can't find them either. A Google search only shows this thread on LS1TECH. It's like they never existed on the interwebz.
I'm going to go out on a limb here and say that I think the OP made a typo when telling us about the great and wonderful EF12RL, because no one can find it.
Try searching eBay for the EF-32RL instead, and I think you'll find either what the OP meant, or else the latest part number for the product that will work.
Here is the description from eBay:
EF32RL Electronic Flasher
Variable Load 2 pin round turn-signal / hazard light flasher. LED compatible, for vehicles with negative ground (just about every modern vehicle).
The black wire must be connected to the vehicle's ground (chassis). If you want a flasher without this wire, look at our EF32SS or EF32SS-R (but those don't make a clicking noise!)
(The listing goes on to talk about polarity, but you can go read that yourselves.)
This flasher replaces:
Bussmann 224, BP224, 232, BP232, 250, BP250, 323
Chevrolet 10039390,10041073,10041074,10178780,11515961,11516 136,15504673,1TF552/5366832,15648653,491391,491392,6450089,9442874
Dominion 743000, 743019, 743054, 743061, 743094
Echlin 562, 567, 582, 582T
Federal Mogul 262
Grote 44530, 44530-3, 44530-5, 44810, 44810-5
Hella 66412
Hobbs 15570-01
Ideal 575V, 752, 752V
Littelfuse 102, EFL102,
Pontiac 10039390, 10041073, 10041074, 491391, 6450089, 6832 10073, 6832 10120, 9442874
Signal Stat 172D, 175, 180, 242, 250, 262,
Tridon EF-12, LF-12,
Truck-Lite 97202, 97210
Velvac 091208, 091215
Wagner 175, 175F, 575, 575A, 575F, BP575A, 592, BP592, 852/5x, 1052, 7210, BP7210, 7212
Brand: CEC Industries
Links: Manufacturer Product Information
SKU: EF32RL
More Info:
Voltage: 12 V
Pins: 2
Manuf. P/N: EF32RL
I hope this helps!
Federal Mogul 262
Hella 66412
Hobbs 15570-01
SKU: EF32RL
More Info:
Voltage: 12 V
Pins: 2
Manuf. P/N: EF32RL
I hope this helps!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130348033861
