those with switchback l.e.d.s come inside
Old Jun 24, 2012 | 04:31 PM
buellxb12s's Avatar
Default those with switchback l.e.d.s come inside
I normally hate to see someone make a thread on such a small thing but unfortunately I have to be one of "those guys." I bought a set of 60 led switchbacks from a non sponsor here. When I got them and plugged them in the drl portion worked but the amber portion stayed solid so I planned to change the flasher. Before I got the chance they stopped working at all. Plugged my regular bulbs back in and they worked so it wasnt a fuse or anything. The 60 l.e.d. must be to big as it was touching the clear corner and the top broke on one of the switchbacks. My question is if you have some will you post a link of the exact one you have. With the ones I had you had to know if you had a ck socket or standard. I would just like to buy some that I know are used and will work on our cars without the guess work. Thank you.
Old Jun 25, 2012 | 06:15 AM
30thanniversaryz's Avatar
I have some of the 20 led one (I believe) and they work perfect.
Old Jun 25, 2012 | 06:24 AM
bene's Avatar
Trunion King
I have the 47 LEDs switchbacks and have been working flawlessly with E-flashers.
Old Jun 25, 2012 | 06:47 AM
MasterV8's Avatar
I have the 30 SMT towers. Had them in for a few years & they still work great.
Old Jun 25, 2012 | 09:07 AM
bad_408_vert's Avatar
where are you getting them from?
Old Jun 25, 2012 | 04:44 PM
Blackbirdws6's Avatar
I would stay away from the 60s. Bunch of people have had issues including myself. Running 48s here without a problem.
Old Jun 26, 2012 | 04:25 PM
Chevyboy454010's Avatar
hey could anyone pm where they got theyres ive only found the 60 smds and i dont want to run into any issues seeing as i have clear housings now.
Old Jun 28, 2012 | 03:19 PM
Mr. Trick's Avatar
I would like a pm also
Old Jun 28, 2012 | 03:32 PM
bene's Avatar
Trunion King
VLEDSdotCOM or SUPERBRIGHTLEDSdotCOM. I can't remember which because I priced them both.
Old Jun 29, 2012 | 04:52 AM
whytryz28's Avatar
On my lt1 the only issue i have is the driver side white doesn't turn off when I use the signal, passenger side works perfect.
