How to fix T-Top Bar on a 1999 Trans Am?
Surely I'm not the first guy who has recently purchased a neglected T/A, right?
Is there a known game plan as far as replacing or repairing these things go, or is it a junkyard or GM replacement item only?
Thanks in advance guys.
^the center bar? Remove the ttops, and there will be 8 phillips head screws holding it down, 4 on each side. BUT, it is held on by a grippy double sided tape, which can be cut through using some thick fishing line In a sawing action. Honestly, I would t even go through the hassle of removing, I'd just tape it off and paint it while still attached. That tape is a bitch to separate. I only did it because I had to remove it to use the targa top.
For plastic trim pieces, depending on sheen/location, I recommend Zaino "Z16 Tire Gloss", , or , although Gummi Pflege Stift tends to work a tiny bit on certain pieces.
