Old Apr 29, 2016, 05:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Cracked Dash Pad Repair
Old Mar 9, 2013 | 05:19 PM
HAZ-Matt's Avatar
Default Cracked Dash Pad Repair
So today I went out to wash my car and noticed the dash pad (aka crash pad) panel had a nice crack in it in the middle.
Went to look at the replacement part and it is like $450 shipped on GM Parts Direct now. Yey for old cars...
I noticed a couple threads where people had repaired the panel themselves with various methods. Including the vinyl covering, but I have some questions.
First off, I am in Texas and so it can get hot in the summer. I saw a couple posts where people that tried to cover the panel in hot climates had problems in the summer. But there were also a vague reference or two that if you used the correct glue the cover would stick, even in the heat. What sort of glue will work well in the hot sun?
Second, I saw where people had painted the panel after repairing the crack. This is actually the direction I am sort of leaning in right now, but I am curious how well these paints will hold up if they get baked in the sun. Saw SEM paint recommended for this. How long does it hold up for?
Would I be better off rolling the dice on an uncracked used panel, or blowing the money on a brand new panel?
Thanks.
Old Mar 9, 2013 | 09:38 PM
my bandit's Avatar
i know that they make a cover that sits ontop of it, its molded ABS plastic. I have never seen what they look like though
Old Mar 9, 2013 | 09:54 PM
jc98ss's Avatar
OP i'm thinking these same exact questions.......my dash pad was great until last summer, now it looks like pure ****
Old Mar 10, 2013 | 10:59 AM
HAZ-Matt's Avatar
I saw that. Not sure that is the direction I want to go.
Old Mar 10, 2013 | 02:29 PM
Daniel Richards's Avatar
the "overlay" looks like *** in the pictures I've seen, it makes it sit up higher, not flush like it should be.
painting is an option but when you go to remove it from the car it's going to crack even more, which shows just how brittle it has become (i've got mine out right now), every time I pick it up it cracks somewhere else so paint doesn't do anything to "support" it.
vinyl wrapping is the best method because it takes some of the stress off the plastic and gives you a barrier from the sun, as for glue standard spray upholstery adhesive should be fine as long as you follow the directions and give yourself plenty of material to wrap around the bottom.
Old Mar 10, 2013 | 04:33 PM
nascarnate326's Avatar
When I finally deal with mine its going to be the ABS from 6LE.
Old Mar 10, 2013 | 05:35 PM
CBAR02SLP's Avatar
Default Cracked dash Repair
Matt...
Have you checked out autointeriors.biz/dashes?
Good Luck
Old Mar 11, 2013 | 11:19 AM
ls1jorge's Avatar
PM Sent
Old Mar 16, 2013 | 10:12 AM
HAZ-Matt's Avatar
Bump
Anyone in the South have luck with the repair?
Old Mar 16, 2013 | 09:59 PM
1961ba427's Avatar
I tried to remove one from my 95 Formula and it busted into several pieces. I attempted to glue it back together in my living room, but it just kept breaking into smaller and smaller parts. Wasn't sure if I was going to just paint it or cover it, but it ended up in the garbage anyway. I've got a nice mat from Lethal Interiors sitting up there now, but still want something better.
Old Mar 16, 2013 | 10:37 PM
beyonddisturbed's Avatar
Mine is also cracked. I am planning on fixing the cracks and fiberglassing it before having it wrapped (or wrapping it myself) in leather. There was a good writeup on it somewhere.
Old Mar 16, 2013 | 11:47 PM
HotWhipT/A's Avatar
This one? Post #8
https://ls1tech.com/forums/appearanc...n-fbodies.html
I just bought 4ft of that black powdercoated aluminum circle mesh. I'll have tons of extra mesh to do others locally and or just sell to someone on here. I plan on wrapping my dash soon. Only thing is, my dash isn't cracked. I bought one years ago and fiberglassed the back side so it would never crack.
Old Mar 17, 2013 | 12:17 AM
1961ba427's Avatar
Originally Posted by HotWhipT/A
This one? Post #8
Thanks for posting that link. I'd like to try a repair like that on my Formula.
Also wish I had thought of fiberglassing the back of the perfect pad in my 97 SS while it was out recently so it never cracks. I'm afraid to try to pull it out again. LOL It would be my luck I would bust it trying to remove it to 'glass the backside.
Old Mar 17, 2013 | 12:31 AM
Zlow28's Avatar
I hate to be the lazy one here but i just gonna buy a dash cover to place on top of my cracked dash. I figure im getting one wether its broken or not, so why bother fix it if ill never see it.
Old Mar 17, 2013 | 01:58 AM
green manalishi's Avatar
that guy did a great job...
...plus it matched the rest of the dash.
Old Mar 17, 2013 | 10:52 AM
Mr. Trick's Avatar
Is it possible to remove the dash pad without removing the entire dash
Old Mar 17, 2013 | 12:32 PM
HotWhipT/A's Avatar
Yes. I wouldn't do it any other way. Just take the A pillar plastic parts off and I think that's it. The top dash is held in by a few clips and some plastic velcro looking stuff. It's a tight fit.
Old Mar 17, 2013 | 03:46 PM
HAZ-Matt's Avatar
In one of those threads, some guys were saying the glue they used didn't end up holding the vinyl in the summer. So I was wondering what glue might hold if wrapped.
I might try just painting first though.
Old Mar 17, 2013 | 09:54 PM
Mr. Trick's Avatar
Cool thanks! Mine has been broken for almost 6 years now and its been driving me nuts I can't stand it. I was affraid I had to remove the dash though, but now that I know I dont have to I'll replace it or wrap it real soon.
Old Mar 18, 2013 | 02:23 AM
HotWhipT/A's Avatar
Oh, it's super easy to take out in pieces!
Getting it back in one piece isn't really hard, just nerve racking.
