How do I remove this damn dash pad!?
I am parting out my Trans Am and I need to remove the dash pad without breaking it any more than it already is. Right now, it's in 4 big pieces and the buyer wanted it so he can piece it back together for some project he's doing.
How do I get the day thing out without cracking more!? Is there a thread on how to remove these?
If it were in one piece and just cracked then I usually start by taking the passenger side up and putting the drivers side all the way to the back corner and with a slight bend it wil
Come out.
Since you've already worked on it, obviously you already have a lot of the screws, panels and clips removed and there are a **** load of them, but you may be forgetting one that is just to the right of where the Radio mounts. Its a blind screw (7mm) that you have to get to from behind the dash, between it and the Ducting that is screwed to the dash. It was the last piece holding mine in. I tugged and shook my dash for half an hour before I discovered it. Once its out, I'm sure the dash will be free.
I also wanna mention that I dropped my Steering Column down to where it was resting on the driver's seat so I could have plenty of room to pull the dash forward and out of the car.
The ABS plastic these dash pads are made of is pretty porous so any of these ideas should at the very least make it less likely to break or crack upon removal.
As for what to do remove the A-pillars then there are several points across the front of the dash that clip into the rest of the dash, if you get those out then you have some velcro pads up toward the windshield to get free with cracking more.
