Completed Wire Mod: Tutorial Inside
Old May 22, 2004 | 12:21 PM
slow's Avatar
approx 3/4" IF you take the connectors apart, and have a small grommet.
you need to do a larger hole if you don't take the connector ends off, and slide it through wire by wire.
Ryan.
Old May 30, 2004 | 04:06 PM
charlesws6's Avatar
Love the way it looks going to do it next weekend will post some pic thanks for the help.
Old May 31, 2004 | 11:22 AM
JohnR's Avatar
This was a great post!
Thanks for all your hard work and nice photography. I copied it to my hard drive so I can refer to it later.
Thanks again,
John
Old Jun 7, 2004 | 04:45 PM
Bird_Of_Prey's Avatar
Originally Posted by lswon
I did the wire mod yesterday since I had access to all sorts of tools and decided to write up a tutorial for the people that don't know how to go about doing it.
Let me know if I made any mistakes anywhere please
Tutorials
Before:
After:
For high resolution images, go HERE
Maybe I'm not seeing it, but where do the wires come in in front of the tire?
Old Jun 9, 2004 | 08:40 AM
lswon's Avatar
There is an opening about 3 inches to the left of the battery. You should be able to see it once you get in there.
Old Jun 9, 2004 | 08:54 AM
Derek98z's Avatar
awesome write up!
Old Jun 13, 2004 | 11:52 PM
JohnR's Avatar
I just finished the wire mod per your excellent tutorial. Now that I've done it, I have one suggestion about the battery ground cable. I believe that you said that you relocated the battery ground cable(s) from the wheelwell to another bolt near the front corner lens. On my '99 Firebird this bolt is painted. I think that this would make a very poor ground. Poor ground connections can cause some very strange problems to ocurr and be very difficult to trace. The factory ground connection on the wheelwell is a self-tapping, plated stud that is screwed in after the car is painted. This makes a secure electrical bond with the car body.
Just my .02.
Thanks for giving me the "Wire Mod" idea and providing all the great step-by-step photos.
John
Old Jun 15, 2004 | 10:20 AM
lswon's Avatar
John, thank you for the compliments on the tutorial. I'm glad it was able to help you out. As far as the bolt goes, mine wasn't painted so I didn't think there would be any problems with it. You can see a high-res shot of it HERE
Old Jun 29, 2004 | 01:10 PM
98BlackBird's Avatar
What is the mod? I came in late and the links and pix are gone.
Old Jun 29, 2004 | 06:52 PM
lswon's Avatar
My website is down at the moment, but as far as what the mod is, it basically takes all your wire harnesses located on the passenger side in the engine bay, and relocates them to your wheel well so that they are out of sight. Give it a couple of days and the website will be back up and running.
Old Jun 29, 2004 | 10:50 PM
Default Wire Mod
Sounds cool! I'll check it out...Thanx!
Old Jul 1, 2004 | 07:32 PM
  #32
Brian2001SS's Avatar
We need to get this web page working so i can do this mod!!!!
Old Jul 2, 2004 | 07:57 AM
  #33
lswon's Avatar
Sorry for the inconvenience... They said it would take about a week for the site to be up and running again. Its been 5 days, so hopefully it'll come on very soon
Old Jul 4, 2004 | 02:30 PM
  #34
Friday13th's Avatar
Site is still down
Old Jul 6, 2004 | 08:43 AM
  #35
lswon's Avatar
Originally Posted by Friday13th
Site is still down
Just received word that my current webhost rejected my transfer request for whatever reason I renewed with my old registrar this morning and page should be up and running in less than 24hrs. Sorry again for this, but it was out of my hands
Old Jul 7, 2004 | 09:05 AM
  #36
Bad30th's Avatar
Finished mine last night !
Only took a few hours, and looks MUCH better.
Bad30th
Old Jul 16, 2004 | 03:45 PM
  #37
Raptor99's Avatar
There's got to be a better way to fill the holes left over from the clips and relocating ground wires. I think it looks VERY tacky in my black engine bay. Is there a way to fill them in and make it look like there's no hole there?
Old Jul 24, 2004 | 05:14 PM
  #38
99MONGOOSE's Avatar
I didn't forget none of the auto parts places had the size I needed so I have to make a trip today to home depot to pick up a small piece of hose.
Although, if you file it smooth enough, I find it hard to believe that anything will get cut on it. That thing is perfectly smoooth better safe than sorry I guess
Summit sells a grommet kit with several sizes; any decent automotive car stereo shop should have a huge selection too.
Old Jul 29, 2004 | 08:20 PM
  #39
eboggs_jkvl's Avatar
5/8" ID grommet and I believe it's a 7/8" hole.
http://www.ls2.com/forums/showthread...threadid=84026
Old Aug 3, 2004 | 10:52 AM
  #40
Toonz's Avatar
Lots of good info here! My car is sitting in the garage engineless so this will be done fairly soon. Thanks for the detailed write up.
