This steering wheel
Old Aug 13, 2017 | 03:13 PM
Donnyd16's Avatar
Default This steering wheel
Would this be wheel work in a f body? Does it need an adapter? Anyone one have it?
http://www.jegs.com/i/MOMO/682/GOT35...IaAsz4EALw_wcB
Old Aug 13, 2017 | 03:21 PM
Donnyd16's Avatar
Also does it need an adapter?
Old Aug 13, 2017 | 04:26 PM
rwb's Avatar
rwb
Yes it will need an adapter. Any wheel can be made to work in any car. Keep in mind if you live in a state with yearly inspections it will fail without the airbag.
Old Aug 13, 2017 | 05:02 PM
Donnyd16's Avatar
Does anyone have a part number for the the adapter? And would the airbag light say on the dash?
Old Aug 13, 2017 | 05:03 PM
rwb's Avatar
rwb
Try Jegs or Carid.
Old Aug 13, 2017 | 05:17 PM
Donnyd16's Avatar
Sorry if this is a dumb question, are they just general fitting or car specific? And are they called steering wheel adapter?
Old Aug 13, 2017 | 05:19 PM
rwb's Avatar
rwb
Steering wheel adapter is what they are called. They should be car specific. Maybe somebody else who has done this will chime in.
Old Aug 14, 2017 | 07:12 AM
drdave88's Avatar
Yes your airbag light will be on since the airbag will be missing. Having that light on will disable the whole inflatable restraints system.
Old Aug 14, 2017 | 02:13 PM
The Batman's Avatar
I have that same wheel in my Bird. Not sure on which adapter I used.
Old Aug 14, 2017 | 05:58 PM
00PewterSS's Avatar
The adapter I used was a Momo 2041. It doesn't fit without modification. I had to cut about a quarter inch off the bottom, otherwise it interferes with the column. You have to remove the clock spring as well. There are a number of write-ups on how to replace the wheel. I would advise you search.
If you don't want the bag light on you can use a 2.2ohm resistor. If you want the other bag to work you need to use a high load 2.2ohm resistor. I have not done this to confirm, you can search here to find that too.
