Custom Firebird TCS Switch Panel
The TCS Switch is the original/stock switch.
The USB Charge Port I bought on Amazon. It has a built-in Volt Gauge and the switch on it kills all power to it (Gauge and USB).
The unlabeled switch is to keep the Antenna down and the the LED next to it is only lit when the Antenna is up.
It is a bit of a prototype now since I think I need to redesign/reinforce the tabs that hold the TCS Switch.
http://www.fadingarrow.net/images/Fi...lled - Far.jpg
https://www.fadingarrow.com/images/F...lled - Far.jpg
http://www.fadingarrow.net/images/Fi...Open - Lit.jpg
https://www.fadingarrow.com/images/F...Open - Lit.jpg
http://www.fadingarrow.net/images/Fi... - Covered.jpg
https://www.fadingarrow.com/images/F... - Covered.jpg
http://www.fadingarrow.net/images/Fi...ront - Lit.jpg
https://www.fadingarrow.com/images/F...ront - Lit.jpg
http://www.fadingarrow.net/images/Fi...nel - Rear.jpg
https://www.fadingarrow.com/images/F...nel - Rear.jpg
I've been trying to keep busy 3D modelling, designing, printing lightsabers. The printer I have is a smaller one (Monoprice Select Mini Pro). I'm tempted to take a look at a Creality Ender 3 or a PRUSA or maybe a higher model when they have a sale. For now, it does what I need alight.
Version 2 of this TCS Switch Panel is being painted right now. The layer lines made the tabs that hold the switch weak in the one above (one tab broke). So I split up the model into 3 pieces so I can print them in different orientations for improved strength and then slot them back together and glue. The new one is much stronger. I printed the front piece "fine" (0.1313 mm layer height) and the rear half "normal" (0.175 mm layer height) settings in CURA so the front would need less sanding and I don't care if the rear looks rougher.
EDIT: Added layer heights from CURA
Final coat of clear is drying now, but assembled and painted it looks pretty much like the previous one above. I'll swap over the switches and USB port tomorrow.
(these are lain on my workbench, not the printer)
http://www.fadingarrow.net/images/Fi... in Pieces.jpg
https://www.fadingarrow.com/images/F... in Pieces.jpg
http://www.fadingarrow.net/images/Fi...ued - Back.jpg
https://www.fadingarrow.com/images/F...ued - Back.jpg
http://www.fadingarrow.net/images/Fi...ed - Front.jpg
https://www.fadingarrow.com/images/F...ed - Front.jpg
(Last pic, I already started sanding the front half.)
There are also Resin Printers out now. However, they need more caution when using and can't print as large. But they produce smoother prints.
I've only been 3D modeling and 3D printing for around 9 months so I'm no expert on this.
I've been using Fusion 360 for 3D modeling.
It has lights & sounds and holds a blade.
Its printed in multiples pieces assembled with threaded rod.
http://www.fadingarrow.net/images/Li...Lightsaber.jpg
https://www.fadingarrow.com/images/L...Lightsaber.jpg
I've heard good things about fusion
Here are pics of the panel assembled and painted.
http://www.fadingarrow.net/images/Fi...ted - Back.jpg
https://www.fadingarrow.com/images/F...ted - Back.jpg
