removed door molding today
Old May 5, 2005 | 04:19 PM
co.6z28's Avatar
Default removed door molding today
just got done and i am pissed. i guess my driver side door was painted b/c you can see where the molding used to be. you can see and feel the difference in the paint. i'm just trying to figure out what to do now. on a good note the pass. side looks great. but the drivers side is making me wish i never took it off i'm thinking maybe i should put it back on. if any body has any idea's please post them up. thanks ahead of time. i'll be in O.C. this weekend and wont be back till sunday. thanks again chris
Old May 5, 2005 | 04:36 PM
SScreaminDemon's Avatar
The only thing I can tell you is put the molding back or repaint the door. I pulled my molding off yesterday and thankfully mine wasn't repainted or anything.
I have got a blister from hell on my thumb now.
Is it the same color? Have you tried claybaring it?
Old May 5, 2005 | 04:40 PM
Parker TX's Avatar
My wife pulled the molding off of mine with a razor blade. Also it could be sundamage, but on the other hand its a 2002 im guessing.
co.6z28's Avatar
yea its the same color(thank god) no i havent tried the clay bar yet but i will when i get back from ocean city. the adheasive came off really easy for me so no bilsters, but i do i a F'ed up door
GM Muscle's Avatar
Is it actually paint or just clear coat? If it's just clear coat over spray a body shop can wet sand it level and you'll never know it was there. I had to do that when I took the badges off my Silverado.
Old May 5, 2005 | 04:41 PM
co.6z28's Avatar
yea its an 02, i dont think its sun damage tho
Old May 5, 2005 | 04:42 PM
co.6z28's Avatar
im pretty sure its the paint but i'll try to get some pics up monday
Old May 5, 2005 | 04:49 PM
Is it really noticeable (significant color difference) or can you just tell where the molding was?
Old May 5, 2005 | 04:54 PM
co.6z28's Avatar
from far away you cant tell. but up close you can see that the paint below the molding is darker than the top.
Old May 5, 2005 | 05:45 PM
02transhawk's Avatar
hmm, find out where it was painted...bet they didn't take off the molding like they should have. They should fix this for you. You can get a carfax and I think find out who owned the car before...or check with the DMV.
Old May 5, 2005 | 06:21 PM
GM Muscle's Avatar
Is the it only the paint that was under the molding itself that's darker, or the whole lower half of the door? If it's just under the molding itself it could be do to the fading of the paint around it. If it's a different color all the way down it sounds like the door was repainted and instead of doing a proper blend they cut the line at the molding. It's hard to find good body shops these days. I would still swing by a reputable body shop though, I'm sure you still have options. And alot of body shops are still only charging $40-50 and hour so it shouldn't cost an arm and a leg.
Old May 6, 2005 | 05:58 PM
BitViper's Avatar
maybe only a toe or two
