SS w/ Center-Mount Exhaust??
Thinking of putting the SLP Center-Mount on my car pretty soon. Does anyone have pics of thier SS's with it. I want to see others to get a better idea of what it will look like. If anyone has a black one that would be awsome. Thanks in advance.!!!
I have had a hard time finding the two oval tips for the CME, the only ones I found where $299 just for the tips. I can get the quad tips and rear lip for that price. Also MeentSS02 what wheels are those?
Steve, that type-r
camaro sure is sharp, very nicely done. I love the CCW''s and the CME. What rear suspention mods do you (better question DON"T you) have? -Jim
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by MeentSS02
CCW SP500s...18x10 up front, 18x11 in the rear.
Kleeborp the Moderator™
Oh good lord...suspension mods. I'm diggin here...sometimes I forget where all of my money went:
Front:
35mm ST Sway Bar
Bilsteins (Strano revalves) with Ground Control Coil Overs, 400 lb/in linear springs, set 1.5" lower
Rear:
Spohn Panhard (poly/poly) for the street...I have a BADZ rod/rod for giggles
Spohn LCAs (poly/poly) for the street...I have LG G2 poly/rod LCAs for track use as well
Bilstein HDs with Ground Control coil overs, 125 lb/in linear springs, set 1.5" lower
BMR upper panhard relocation kit
BMR bolt-on relocation brackets
SLP bolt on subframe connectors, welded in
25mm ST rear sway bar
LG G2 torque arm
I *think* that's about it.
As for the wheels, go to ccwheel.com.
Front:
35mm ST Sway Bar
Rear:
LG G2 torque arm
Oh, and the tips are painted if you didn't notice:
![](http://www.image-hosting.net/images/messageboard/MeentSS02/IMG_0979.JPG)
Only the edges are untouched...
I have Loudmouth right now, would I be able to adapt the CME somehow. Is there a kit to make this work? Also, does the valance come painted? Thanks for the pics..
I have been looking at SLP where you can upgrade your Loudmouth for $325
http://www.slponline.com/view_product.asp?P=30259
However I haven't been able to find the ovals. I did see some for just the tips $300 but you still need the tubing and valence.
No, the valance does not come painted. Its bare plastic.
left pipe
right pipe
centerrmount system with muffler & valance
valance
