View Poll Results: What are generally the three most important aftermarket guages to have?
Multiple Choice Poll. Voters: 261. You may not vote on this poll
I've been thinking about getting Autometer guages installed and have decided that I need the trans temperature guage to read my A4 temperature, the air/fuel guage to see how the car's air/fuel ratio is on the drag strip, and the water temperature guage just to get a much more accurate temperature reading of the car (compared to just using the inaccurate '99-up factory temperature guage). What do you think are the three most important aftermarket guages? Thanks in advance for the info.
I think it depends on the route you go. If you go force induction, you need a boost gauge, probably fuel pressure and a/f at least. If you go spray, you'll want bottle pressure, fuel pressure and again A/F.
But being it sounds like you're keeping it n/a, the gauges you have listed are pretty good. Trans temp is a great one at least. I think you can make an arguement for all the gauges you have listed being important but for your setup the route you're going should be a good one.
Originally Posted by steveo346
i always wanted to see what a fourth gen camaro would look like with some aftermarket gauges in the insterament panel
im goin with an A/FR(connected to wideband) gauge in one of the A/C vents, and trans temp, water temp, rear diff temp, and fuel pressure in a panel for where the radio goes(with quick connect harnesses, more on that when i get on it). id say a AFR gauge isn't really any benifit without a wideband hooked up to it. the stock O2s are just not good enough to monitor in real time
LS1Tech Sponsor
What about a bolt on car? I want some gauges but cant figure out which 2 would actually be the most useful for me? I need trans temp with my stall, but what other 2 would BEST suit me?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Originally Posted by chaman
IMO you should include an Interceptor Gauge. It monitors a LOT of those parameters including trans temp and is also a problem code reader...I got one!!!
Originally Posted by Trojan35
pics of it mounted?
upper one is a D-PIC Autometer unit, lower one is the Interceptor Gauge. Dont mind the bolts...Ive taken care of them!
