PC not removing scratches - What next?
I have rubbed my Fiero with the PC, orange pad, and 3M Rubbing Compound #39002 and still scratches remain. These scratches are similar to some I have on my TA that I want to remove. But I want to have the process down before I attempt on TA. After the compound, I went ahead and did the 3M polish followed by the Meguiars was. The finish is incredible. Wet, deep looking, and slick - but the scratches are still there. The 3M is the fine cut compound and they have a heavy cut. Do I need to do that with a yellow pad, or should I go straight to the Turtle Wax rubbing compound? Input is greatly appreciated.
How deep are these scratches? If they go down through the paint, all the compounding and polishing in the world won't help you. If you can feel the scratches with your fingernail, chances are they are through the clear and either into or through the paint. Is it one spot or all over the car? Can you get some pictures of them?
-Mike
-Mike
-Mike
-Mike
You beat me to it. If they are past the clear coat then you cant really get them out. You might also want to try scratch-x it works out really good for me. You need a lot of elbow grease though.
-Brandon
The scratches are not thru to the paint. They look like where a cat has slip down the hood. They are very hard to feel if at all. And from a foot away, to can't really see them but they are there. I will try to get some pics tonite if that will help. I used the orange pad with moderate to heavy pressure with the 3M Fine cut compound. I worked it in at 5 on the PC until it was almost gone, then slowed down the PC to 3 1/2. The finish is not as dull as I would expect from the compounding. Am I missing something?
How much polish are you using per section? How long are you working each area? How many passes are you making? Have you tried speed 6 using moderate pressure?
With a PC, you really have to have patience...defects won't just magically disappear. It takes time and effort.
I am using about 6 nickel size drops per 2 x 2 section with orange pad. PC is set on 5 and for the hood I used moderate to heavy pressure, north and south strokes, followed by east and west strokes. I work it in until the compound is almost gone. This is about 15 mins. Maybe I need to repeat the process again? On the wing, I went ahead and polished it with the 3M polish thinking that would remove the rest of the scratches, and put a coat of Meguiars wax on it but the scratches are still there. The finish is incredible and I can't wait to do the TA, but I just want to make sure I am accomplishing my goal (elim scratches) with the process. Thanks for the input so far!
Last final desparate attempt at scratches, I hit the hood last nite with the 3M 390002, orange pad, PC set at 6 and moderate to heavy pressure pressure. No luck. Actually, it looks like I swirlled even worse, hope polishing takes that out. Some of these scratches you can feel with your finger nail. Not sure I want to attempt wet sanding, but may have no choice now. I am trying to get some body shop input now. Thanks for all the input. It has been a great learning experience.
Before wetsanding, get an experienced person to go over it with a rotary.
I've never had that much trouble with any finish. How many times did you go over the area?
Twice. First time with light to moderate pressure with PC on 5. Second time, moderate to heave pressure with maching on 6. That PC on 6 is a handful. Keep in mind, the car is 21 yrs old, but the paint is pretty good. the scratches have been on there awhile. It is shaking my confidence to do this. But I am in no real hurry. Except, I never drive the TA in the rain, EVER. Now, it is raining like crazy, the Fiero is 1/2 done so I am forced to drive the TA in the rain. Maybe the only time this will ever happen. BTW, I was going to do the rubbing compound w/towel only, not PC. Feel like I could do some major damage.
Can you feel these defects with your fingernails? Are your pads turning black when you polish?
As I said before, correcting serious defects may take several passes with the PC.
Some of the scratches you can feel with fingernail. And those I am not concerned about as the ones you can't feel but can see. I tried taking a pic last nite, but it doesn't show very good. Hopefully, I can get some pics in normal daylite.
As for the pads, they do not get black on them. Is that a good sign or a bad sign?
Went over the hood again last nite w/orange pad and 3M Fine Cut compound. Although, the scratches are still there, it seems as though they are getting harder to see. At this rate it would take 3-5 more passes to remove them from clear view, but not from the surface. I put some Turtle wax Rubbing compound on one of the scratches. It did nothing for the scratch, and actually scratched the surface. Most of it come off with 3M but it is still there. Won't do that again. Got some 1500 and 2000 3M sandpaper. Going to try the wet sand on an inconspicuos scratch. Does 8 times seem normal for scratch removal?
