Has anyone ever used Eurolamps? Results?
I've got one of my high beams out, and would like to brighten up the low beams as well as long as I'm at it. Any simple recommendations for a T/A to give off a brighter light? I'm pretty much looking for something that bolts directly in and doesn't have to deal with much wiring.
Here's one of the set I was looking at, about $180 for everything with the Xenon-Charged Blue/White True High Output Conversion kit:
eurolamps.com/eurolamps/camaro_headlights.htm
Anyone use it or have recommendations?
Last edited by LawmanSS; 04-25-2006 at 04:13 PM. Reason: Non-sponsor link removed.
They work as advertised and are a snap to install, however a few days after I put them in, I went to install Silverstars (didn't like the stock bulbs) and noticed that one of the housing lenses had a nice big crack in it.
Don't know if it's a heat related crack or if a rock hit it. Either way, didn't happen for 4.5 years with the stock housings. I don't know if anyone else has had anything like that happen, but just FYI.
Oh, and the housings + Silverstars are MUCH better than stock.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
I don't have them in yet, but I recently purchased that same "conversion kit". A couple items that I noticed...
1) The link you posted says:
However, all you get are the new housings and the bulbs. You will be directed to your local parts store to find the wiring adaptors that you need.
2) The 4701 (high beam) housings are identical to the 4703 (low beam) housings. There is no difference in the lenses or the reflectors. So the beam pattern will be the same. This stock headlights at least have different lenses. I haven't pulled them yet, so I don't know if the reflectors are different or now.
Also, now that Eurolamps have my money, they're not responding to any emails. So make sure you ask all your questions up front.
Our kits come with Everything you need for easy conversion to Bulb-Type headlights...New Housings, High Performance Bulbs, Plug-in Wire Adapters, & more.
Eurolamps told me that some low and high beams are contained within the same lens and use a common reflector and therefore have the same pattern. This is true on older two headlight cars.
With using the same housing for both beams, all you're doing is throwing more light to the same area, not beaming it further (and higher) down the road.
But, everyone seems to be fairly happy with them. I'll see once I get mine in.
I have these, I wasn't impressed with the Xenon bulbs they sent with the kit. The white/blue tint was nice, but it seemed like they put out less light than the factory bulbs. So I switched to Silverstars and things improved quite a bit. I haven't decided if it was worth the cost yet but I already had a low beam out so I thought I would try them. As far as adapting them to the stock wiring, the prongs for the H7 bulbs are too wide to fit directly in the factory harness. I made an adapter myself by putting a female spade connection on one end of a 3" piece of wire (14G I think). On the other end I had to cut a male spade in half (making it half as wide), which fit perfectly in the stock harness. You have to make 2 of these wires for each bulb. Taped it all up and it worked great. I was determined to not spend any more money on them so I don't know if you can buy anything like this pre-made or not.
Originally Posted by Custom4204
You didn't like the bulbs they sent or the stock bulbs that were in the car from the factory? Were they just pretty weak?
dude screw paying 180 dollars.. i have silverstars in my stock ones....take it out...get a screw driver and stick it under the plastic ring and twist...that will break and fall off...then just grab the bulb and turn it(you have to break the seal) and the old bulb will come out...then just buy the silverstars and buy some of the copper gasket/adhesive from autozone and put that on the o-ring section...slip the bulb back in and then rub the copper stuff around the edges...mine have never came apart nor leaked and looked 10000+ times better than stock for a 45 dollar upgrade and the copper stuff is nothing like jbweld or something so if a bulb goes out and you need to replace it..it will break lose so you can do it again
This works on the older two headlight cars because the light bulb has two filaments that are placed in different places within the bulb. The placement of the high beam filament is different (rearward I believe), thus varying the focal point of the light ray, which changes the beam pattern.
Someone else that had bought the kit pried the socket from the Eurolamp "high beam" housing and then glued the socket to a factory high beam housing. He was satisfied with this because it not only gave him the correct light pattern but set him up to swap bulbs anytime he wanted and even made a path for HIDs when he wanted to make that transition.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I got them on special awhile back for just the housings without bulbs, and I'm using Silverstars now. They work pretty well, a lot brighter than stock. I'd still like to go to HID someday though. But at least I have housings that would make that easy now.
Where are you guys pulling $180 out from? It's $88 for a kit, that's left AND right. You're not including high beams, are you? Why would you even worry about upgrading highbeams that you'll rarely use? The lowbeam conversion is all that you really need, so figure $88 for the lowbeam conversion. Not sure what adapters you guys are talking about either, must be a Pontiac thing, as the Camaro was directly plug and play.
I have the Eurolamp Conversion Kit for my low beams on the T/A. I used the Philips Bulbs and am very happy with the difference from the stock light output. I had no problems with the cracking issue and when I bought them they were not stating that harness adapters were included.
I did however, find the harness adpaters needed to mate perfecly with your stock wiring harness with out cutting it - I just have to remember where I got them at.
Please Stand By........
-Jay-
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Jay-
You don't need an adaptor, just cut the old plugs off, splice some additional wire on, and attach the new plugs. It takes like 10 minutes, and if you converting them, you won't change back.
Didn't say you did need an adapter - but if you don't want to cut your factory harness - that's the way to go. I agree that I will never remove mine - but I also don't ever plan on selling my car.
Lot of people sell their cars then want to return them back to stock...
