LED Brake-Lights in Firebird housing...
I'm looking to eventually get almost every bulb in my car switched over to LED's and the one I am having trouble with are the brake lights. I could have sworn I read on here about the difference between red and white LED's along with some pics to back things up. I also remember reading about the issue of daytime and the lights being difficult to see. The last thing I want to have a problem with is someone not seeing my brake lights, but with a lot of the interestinh designs I see...I'm willing to try things out.
The main question is....do you go red or white in the LS1 firebird housing? Also, how is the difference between low power when the headlights are on compared to the light output when applying the brakes?
Thanks. If I get some decent answers then I will probably guinea pig myself and let everyone know the results.
-Brian
-Brian
Red LED's give the light a more red look through the plastic. As far as I'm concered the LED towers dont generate enough output to see anything during the day. If no one posts pics theres plenty of conversation on this if you search.
Copy & Paste Moderator
I dont have experience to back it up, but I've read on a vendor's site that since the red lens blocks all light except red and Red LEDs only produce Red (unlike a red bulb which is coated red), the Red LEDs will shine better than the white ones (which will have a portion of their light blocked, same logic for Amber LEDs and Amber lenses). Like I said, I have no experience with it, but it does make sense (I remeber some light dynamics from school...its been a while). Anyone wanna do a comparison?
Sounds like I have a good idea of what I want to do and which color to go with. Thanks for the help and I will post pics of my results when I go ahead and do this mod. Btw, any comment on the difference in light intensity between the nighttime light and when the brakes are applied? I want to make sure its a noticable difference in output.
BTW, is the search function broken or something? I tried a bunch of times to run generic searches but it comes back with it not finding anything.
-Brian
-Brian
I tried to do the LED conversion also on my tail lights. So far ive failed everytime I cant get it to be the same brightness as bulbs. The problem is LED's are directional and our bulbs use reflectors to send out light
I thought about doing this with a massive amount of LEDs pointing straight back towards the viewer. LEDs dont have much variance between their minimum voltage and maximum voltage, so it's not very easy or practical to try and "dim" them. What I would do if I ever got around to it, would be make the grid for each light and space them. So when the brake is hit, all of the LEDs light up. When its just normal running lights/etc, only every other LED would stay lit. here is a diagram:
Normal running lights, half brightness like you're driving down the road with the lights on:
![](http://mindmod.com/off.gif)
Brakes depressed
![](http://mindmod.com/on.gif)
Obviously they would be close together, not spaced out so much like they are in the diagrams. This is just an example.
I think this would work really well, and one day I will do it in my TA if I get a lot of free time. Personally I think the LED towers are a total waste of money, and a really bad substitute for something done right like above.
Brakes depressed
Originally Posted by evilbadz
I thought about doing this with a massive amount of LEDs pointing straight back towards the viewer. LEDs dont have much variance between their minimum voltage and maximum voltage, so it's not very easy or practical to try and "dim" them. What I would do if I ever got around to it, would be make the grid for each light and space them. So when the brake is hit, all of the LEDs light up. When its just normal running lights/etc, only every other LED would stay lit. I think this would work really well, and one day I will do it in my TA if I get a lot of free time. Personally I think the LED towers are a total waste of money, and a really bad substitute for something done right like above.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Restricted User
hmm ive been interested in seeing something differernt in the LS1 bird brake housings but havent got to it either...i want to put LED's in there, and dont care for daytime brightness but i do know they will be bright at night when i turn the lights on, someone do this and post pics already!!!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Brian
-Brian
Brian,
Hurry up and post pics so I can do mine. I want you to do all the R & D and let me reap the benefits
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I did not bite the bullet yet on trying LED towers as brake lights but I may just be cheap and pull out the two towers I have and throw them into one housing to compare. I am actually not too worried about the lights when its dark, but in the daytime...I dunno. I think I should have some time come Sunday to give this a shot.
I got done the map lights and courtesy lights (came out great), but I wasn't thrilled with the 194 LED I tossed into the license plate light. If I give this a try on Sunday I will def post pics. The only ones left on the exterior are the two rear corner lights, brake lights, and third brake light lamps.
-Brian
-Brian
