Lighter hood struts
010433810
288 / 96 C
They are the same numbers on both shocks. They are stock on a 1997 SS. They are MUCH LIGHTER than the shocks that came on my Firebird with the stock steel hood.
The Firebird struts are marked considerably different. They are marked as follows:
STABILUS
USA Gastonia NC 28052
4892EV 0330N
132 / 00 B 21
STABILUS
10201454
148/97 G
Ok so now I'm wondering. I'm thinking the 3rd set of numbers, which appears on every set I have, is some sort of manufacturer's date. The one's on my SS are marked 96, the car is a 97, so it makes sense they would use the same struts from the 96 model.
The first set of Stabilus struts are from my 00 firebird. The numbers match the 00 stamped on the strut. This new set is marked 97, which has to be accurate because I bought them from a 98.
Basically, it might be a shot oin the dark, but I believe we need to find a set that is marked 96. I think those are the only ones that will be the exact psi we are looking for.
Someone correct me if I'm wrong.
I mean, for 9 dollars, I guess it was worth it to find out if they would work. Not a big deal.
STABILUS
10201454
148/97 G
STABILUS
10201454
148/97 G
...and if it is anything like Mopar then "148/97" would mean the 148th day of 1997
STABILUS
10201454
148/97 G
93-97 camaros
93-97 birds
98-02 camaros
98-02 birds
they all are differant part numbers, i found 5 brands, mighty lift, sachs, strong arm, arvin, monroe and napa does not say the brand name. but napa does say the length's and the birds are about 3" shorter
camaros open to about 22.5"-23'
birds open to about 20"-21"
dont know if that helps any one
the stock hood struts are rated at 70lbs a lil over 300 neutons
i found a company that makes custom lift struts and for aprox 120 shipped you can have custom lift struts made
he said the 40lbs 103 neutons would be a good place to start. any ways i will be more then happy to give this a shot if you all are interested maby a GP
Yea mine does the same thing its the front hood spring that pops the latch on your hood its a lighter hood so its going to fly up faster like its a rocket lol.....im still interested in finding some easy struts for the hood........
