Lighter hood struts
Old Aug 29, 2008 | 08:52 PM
  #161
bad6as's Avatar
Originally Posted by LS1Zedder
Thanks a lot man! Just got mine and they work perfectly with my Sunoco hood. Same size as stock. I went with the 35 lb force.
glad there working for you! mine are still great, i just dont know if i went with the 25lb or 35. i think i did 35
Old Sep 12, 2008 | 06:20 PM
  #162
mvvette97's Avatar
does it hold the hood ok? Also does it seem alot lighter than the stockers? Also how do you choose what pound struts ya want to order? I don't see an option
Old Sep 12, 2008 | 07:28 PM
  #163
bad6as's Avatar
ill get a video of how much effort it takes to lift/close my hood.
it holds it up fine
Old Sep 12, 2008 | 08:46 PM
  #164
mvvette97's Avatar
cool, thanks bro... Is there a place on the order form where you can choose the poundage you want?
Old Sep 15, 2008 | 11:47 AM
  #165
mvvette97's Avatar
it holds it up fine
Just wondering if you got the video yet and what pound did you end up buying? thanks man
Old Nov 27, 2008 | 02:07 PM
  #166
myk's Avatar
myk
it holds it up fine
I found the site that you mentioned. What were the 'specs of the struts that you ordered? You'd be helping alot of us out...
Old Nov 27, 2008 | 02:46 PM
  #167
bad6as's Avatar
all i did was go to strong arm and mighty lift. they make oem struts and go the lenghts from them, then i found the same lenghts on orrorr and took a guess on weight. i think i did 35lbs.
stock hood 50lbs and the struts are 80lbs force each. so some math go me in the low 30s range.
the car is at a friends house, im puting a full spool in the rear, ill get the part number off the strut.
gobble gobble
Old Nov 27, 2008 | 03:27 PM
  #168
myk's Avatar
myk
Much appreciated. I don't see the matching lengths from 20.02" extended and 14.29 compressed, so I'm guessing they make custom lengths? Or can I just go with something close to the OEM lengths? Also, do you pick metal or composite ends?
Old Nov 27, 2008 | 04:38 PM
  #169
99_Z_155's Avatar
just fyi, i got a fiberglass ss hood, and got 35 lbs. struts, and they will BARELY hold the hood up. i guess im going to nee some stronger ones. if its cold out, they wont hold it at all.
Old Nov 27, 2008 | 04:54 PM
  #170
LS1Zedder's Avatar
Here is the direct link for Orr & Orr.
http://orrorr.thomasnet.com/viewitem...easuresortid=0
The Orr & Orr part number is H-9505 and the second number is the poundage. I went with 35 for my Sunoco and it works perfectly. These are Stabilus brand struts.
The Stabilus part number for the 35 pounders is 752959. You can find other poundages using the PDF link on page 8.
These are for Camaro hood struts. Firebird ones are shorter. You can buy a strong arm brand for them. Those part numbers are on page 7.
Old Nov 27, 2008 | 09:38 PM
  #171
myk's Avatar
myk
Thanks for the information, guys. On ORR's page I guess I'm going to go with either the 35 or 45 pound struts that extend to 23" and compress to 13.2". Once again that's a little different than the stock 'bird struts that extend to 20" and compress to 14", but I don't see why it would be a problem.
Of course, we've got two members here who've had two different experiences with the 35 pound struts; they either worked great or sucked from time to time. Hmmm...
Old Nov 28, 2008 | 01:46 PM
  #172
bad6as's Avatar
camaro struts will not work on a firebird
Old Nov 28, 2008 | 02:50 PM
  #173
Snuffles's Avatar
I put lighter hood struts on my car when I put my Sunoco hood on about 4 months ago.
Info was rather sparse and sketchy so it was tough to nail down a part number.
What I did was went to Strauss Auto with one of my stockers in hand and went through the struts they had.
Luckily, I found one that worked.
The part number is SG214012. The struts are made by Stabilus/Sachs.
The struts are rated at 175N (stock Z28 is 345N) which comes out to a hair under 40lbs.
Extended length is 25" and the compressed length is 15".
The only issue with these struts is that they are ~2" longer extended than the stock ones.
This means the hood will open more. I didn't have an issue with it but some might think it looks weird.
I'll see if I can get some pictures up tonight.
Old Nov 28, 2008 | 04:03 PM
  #174
Snuffles's Avatar
Went out and took some 20-30 minutes ago ....
BTW, about a week ago I opened the hood to see if the temperature had an effect on the struts.
At 35° there was no problem.
Old Nov 28, 2008 | 08:59 PM
  #175
Outlaw LS1's Avatar
Originally Posted by phantomzer0
I talked to Armando about lower psi hood struts when I picked up my hood. He insisted that the regular hood struts will NOT damage a VFN hood through the course of the years. You should be safe.
dude my vfn ws9 hood has mad creases in it. All i know is vfn hoods cant hold up to south fl humidity or heat. thats for sure
Old Dec 1, 2008 | 12:04 PM
  #176
PERFECT Z28's Avatar
I just ordered the ORR & ORR Inc. part# H-9505-25...we'll see how they work when I rcv them.
Old Dec 1, 2008 | 01:47 PM
  #177
myk's Avatar
myk
I went with the 35# ones, let's see how this goes...
Old Dec 2, 2008 | 11:31 AM
  #178
Crows93Z's Avatar
i heard this too when i picked up my hood... but i've seen creases developing.
Old Dec 6, 2008 | 05:18 AM
  #179
myk's Avatar
myk
Received and installed my #35 hood struts, part #H-9505-35. The hood opens too much, which leads me to believe that I could've gone with the shorter 19" strut. Also, the #35 rating may be too low. Once the hood is at a 45 degree angle the hood closes itself. Not a major problem, just a nitpick. I'd recommend this to anyone who has an aftermarket hood...
Old Dec 6, 2008 | 07:11 AM
  #180
bad6as's Avatar
firebirds struts are shorter.
