CAUTION! To those who wash their engine...
Fast forward to me getting a SES light. It was the code for the front knock sensor. Upon removing the intake, you could see where the water had seeped under the intake and corroded the front knock sensor.
It was rusted and looked like crap.
The rear one was still gold and looked perfect. I replaced both knock sensors and made a new harness and installed it. I then followed the service bulletin on applying RTV sealant around the grommets to prevent water from seeping back down to the knock sensors.Now, if you have never pulled your intake off, you will probably break off the oil pressure sending unit.
Only way you won't break it is if the "gods" are looking down upon you. So, if you are going to swap your intake, go ahead and buy an oil pressure sending unit for insurance. By breaking mine after all the dealership parts places closed, it had to sit in the garage at a friends house all weekend.
Big props to him for helping me and letting it sit in his garage.
While I didn't have the Z28, I had to drive the beater car... the Z06.
Just a heads up for anyone who washes their engine.
Justin
Yea, I broke my Oil sendign unit putting my intake on
I have never once had a problem with water getting into the knock sensors until recently. I dont ever wash my engine either, but the car does sit outside in the crappy washington weather, so I am guessing one finally got some condensation in it and lunched one. The intake will be coming off aagain once I get the car back from the cage builder to try and fix the problem.
What a PITA fix for the knock sensors.
Although, when I turned the key and she started...
