Interior mod.
http://www.google.com/search?q=autom...ient=firefox-a
Enjoy!
And to OP, bangin' interior bro!
Enjoy!
Sold from a sponsor. I'm not to sure about the colored stuff.
I placed my old carpet on the new one and started to cut out some areas to have the new carpet to fit in the car. Carpet was also like 4-5 " shorten that stock , in the rear. But other that that it was very nice and very black.
If you want a carpet fit in the car right out of the box- buy GM, aftermarket must always be trimed.
Also what about the passangerside airbag? Will you be cutting in around it or did you disable it & just gonna fill in the indentions & cover over it??
The dash is more difficult to work on since it is soft, hard plastic panels is much more easier. Regarding the air bag i simply cut the vinyl once it is in place, maybe i will put some kind of strip/trim later.
I found a area to the right of the middle air vents beeing very difficult due to you need to strech the vinyl in all directions-this area i'm still working on(need to find out a clever solution for this ****
). Also the passanger end is quite difficult, you really need to have patience and no rush, then it will look like ****. I'm not completed yet but work is going forward
But just wanted to let you know that the airbag cover, is just that, a cover. All it is is a piece of rubber thats glued to the dash. So you can just pull that off, and vinyl it seperately. Its VERY strong adhesive though, but i just used a hair dryer and wedged a screwdriver between the cover and the dash, just working around, and it came off perfect. Its not plastic so it wont crack. That should make covering that part a bit easier! But good look with finishing it up, looks great so far!
