Window alignment write up
Old May 12, 2015 | 05:57 PM
  #61
EnergyCC's Avatar
About to do this today! Hopefully no more wind noise....
Old May 28, 2015 | 12:15 PM
  #62
Bachert24's Avatar
Going to work on this myself tonight after work. I can't believe this keeps getting brought back from the dead, but I am thankful it was so easy to find! I am having to do this on my 95. And I have the other issues some other members have mentioned, like the slowness of the window rolling up unless I pull on it while I push the up button. Might be corroded contacts so I am gonna try that first. Unfortunately this window has been leaking for years from what I can tell and the floorboard behind the passenger seat is rusted completely through. Of course that happens while the car is for sale. Wonder if someone can weld in a new piece for me?
Old Aug 30, 2015 | 11:39 PM
  #63
TtopTA's Avatar
This needs to be bumped again. Just saved my *** today in a very very leaky Trans AM. If anyone has a broken window alignment bracket they are still available. The OE part number is 10257988 and a company called Dorman makes an aftermarket unit, part number 45359.
Old Mar 29, 2016 | 02:57 PM
  #64
johnp94's Avatar
My window is wobbly, I can move it front to back by hand. It gets caught when shutting. I need to steady it with my hand for it to go up smooth. What is the fix for this issue.
Old Jul 3, 2016 | 06:55 PM
  #65
alaska_guy's Avatar
Resurrecting an old thread... I tried everything you listed and was able to get the window 90%, thanks for that!
However, it seems like my window needs to move towards the rear of the car more. I have a gap in the rear of my drivers side that will allow water in still... Any ideas how I can move the window forward and aft?
Thanks for the write up! Helped me out!
**EDIT**
Looks like there is a number 5 labeled on the door, I undid those bolts along with the bolt below on the arm and it seemed to almost get me there. I am sooo close now. Shouldn't really get much road noise, but if I go through a car wash I am sure I would still get sprayed. Hopefully that helps someone else out if they are having the same issue.
Old Jul 4, 2016 | 05:25 PM
  #66
alaska_guy's Avatar
Took me a couple hours each day over the weekend fiddiling with the adjustements, but finally got my window acceptable. There is a "tiny" gap in the back that may allow water in still, but hopefully I am ok now.
Thanks again for this tutorial.
Old Jul 7, 2016 | 07:58 AM
  #67
cancam99ss's Avatar
Doing this !
Old Jul 9, 2016 | 06:47 PM
  #68
z28pat's Avatar
I am trying this as soon as I can !
Old Dec 11, 2016 | 01:53 PM
  #69
Sean Stocking's Avatar
Default Not sitting against outter window sweep
I have my window brush assys tight against the windo and still have a gap near the mirror where water is just pooring in wondering how i can get the window against it thanks!
Old Feb 10, 2017 | 02:00 PM
  #70
strikeone's Avatar
Originally Posted by sneaky7980
5. Lastly I tried moving the fwd end of the track full down, (D). The front of the window went full up so i closed the door and i'll be damned, tighter than a frogs ***!!!
thanks for this helpful write-up, sneaky7980 - my driver's side window is now tighter than a frog's ***!!
Old Mar 24, 2019 | 09:59 PM
  #71
Chris Anderson's Avatar
I have this issue where the driver side window isn't fitting against the weatherproofing. Is there a way I can adjust the window or do I need new weatherproofing. There isn't even an indentation where the window makes contact with the weather strip shown on passenger side window.
Old May 6, 2019 | 05:25 AM
  #72
Just hoping that someone might reply?
Old May 6, 2019 | 10:45 AM
  #73
bammax's Avatar
Try to adjust the felt pads on thettop of the door inward some. That'll let the glass lay towards the car more which may get you the seal you need
Old May 6, 2019 | 01:21 PM
  #74
Thank you! I'll give that a try today.
Old May 7, 2019 | 03:03 AM
  #75
So i gave it a try, its still not the same as the passenger side. but its much improved. any other suggestions?
Old Aug 28, 2019 | 09:56 AM
  #76
kyoytey1693's Avatar
Man this is a great thread. I've used it several times over the years. However, new car, new issue. My drivers side window causes so much resistance against the seals that it makes the door difficult to close. With the window down it shuts great. There's a gap between the outer window felt and the glass. I've tried to adjust the glass out with the 2 jackbolts at the rear as well as move the inner felts all the way out towards the glass. That helps but it puts too much of a bind on the glass when going up and down.
Any suggestions?
Old Sep 6, 2019 | 07:05 PM
  #77
mctabish's Avatar
When I got my 2000 Camaro SS Convert, both windows were (and still are!) jacked up. I am not sure how there are to align to the seal with the top. Does anyone have a few pictures for how the windows and the seals should match up? It it to the TOP of the gasket (that is where mine are) or is it in the slight channel that is about 1/4 way down? If I line it up here (just by using the up/down) it seems the the little forward triangle the the mirror mounts to is too tall as the window is down about 1/4-1/2 inch.
I take a bath in every freaking rain and I collect about 1/2 of water in the floor boards which stands... (need to replace carpet due to mold- but want to get it sealed first!)
Thanks!
Bruce
Old Sep 12, 2019 | 07:36 PM
  #78
JD_AMG's Avatar
Thanks!
Bruce
If im reading what you are asking correctly, the window is supposed to be kinda under the rubber seal at the top.
Check this link:http://shbox.com/1/adj_window.html
Old Jun 9, 2023 | 11:59 AM
  #79
johlks's Avatar
Any suggestions?
I have this same issue, what did you end up doing to fix this particular window alignment?
Old Apr 20, 2025 | 05:14 PM
  #80
Docrocket1967's Avatar
Just wanted to say that in 2025 this thread was still helpful in fixing my gap at the front of my drivers window.
