Squeaking noise from the back of the car.. WHAT IS IT?
Old Sep 21, 2007 | 01:59 PM
DANSBIRD's Avatar
Default Squeaking noise from the back of the car.. WHAT IS IT?
It's driving me insane! It's somewhere in the back of the car. I thought it may be the latch for the hatch, so i sprayed down WD40, also all in the area where the jack/spare tire is as well. Anyone ever run across this? Iv about decide to just start taking out carpet and everything and WD40ing the entire rear of the car... anywhere that metal is touching metal. But thats a lot of work, was hoping someone had run across this before and found out the cause of it.
Thanks
Old Sep 21, 2007 | 02:05 PM
colby72olds's Avatar
mine was doing the same thing, the spare tire was loose. Also, do you have an after market PRH?
Mike@ZMS's Avatar
Put the rear seats down and see if that makes it go away.. I have a squeak also, and thats where its coming from.. the latch.
Old Sep 21, 2007 | 02:42 PM
DANSBIRD's Avatar
Yes, i do... It doesnt sound like it's coming from outside of the car... but i guess, it COULD be?
I'll try putting the rear seat down as well, but it sounds like it's coming from further back than that.
Thanks for the suggestions
Old Sep 21, 2007 | 03:02 PM
Flamin' bird's Avatar
I have the same thing and I can't figure the damn thing out! Sounds like metal and we thought it was a exhaust clamp but checked everything under the car....everything was tight as can be. I checked the spoiler..tight there. Its annoying. Even when you close the hatch you hear it and it sounds like its coming from under the car. In fact I know it has to be because with the windows down I can hear it echo off buildings when I'm passing by one close or other cars
Old Sep 21, 2007 | 03:14 PM
catfSSh's Avatar
mine was a loose bolt in the sub frame connectors me and my friend put in
Old Sep 21, 2007 | 03:25 PM
DANSBIRD's Avatar
Umm... i think we may have 2 different issues here. Mine only happens when the car is on the road. I cant get it to do it just sitting still. Something is vibrating and making it squeak.
Old Sep 21, 2007 | 03:26 PM
DANSBIRD's Avatar
Hmm... my SFCs are weldon. IIRC, this has been going on since before i even put the PHB on.
Old Sep 21, 2007 | 04:00 PM
Giddswat's Avatar
Try the upper shock mount bushings, I lubed and tightened and no noise.
Old Sep 21, 2007 | 04:03 PM
DANSBIRD's Avatar
Will do... Thanks!
Old Sep 21, 2007 | 04:12 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
I MAY have the solution......mine was driving me nuts..thought it was springs or new Bilstein shocks..finally got mad enough while cruising..got out and looked..stood on me right rear tailpipe a couple times..same with left..do not know what made me do it all of the sudden like that..drove away..fine..stopped and looked....pipe was juuust touching the frame and rubing very lightly..and I mean LIGHTLY..hardly a mark at all.....been fine for 2 months....check it out..g'luck.
Old Sep 21, 2007 | 04:18 PM
DANSBIRD's Avatar
man.. i hope this isnt something happening underneath the car. I'll have to get a friend of mine to drive it while i explore the back of the car. I was wondering if it were possible for it to be something b/t the inside of the car and the tail lights.... but i dont think theres a lot of metal in there.
Old Sep 21, 2007 | 09:51 PM
Thumpin305's Avatar
I recently had this happen to me. After taking the back interior of my car out twice, I finally had my dad drive my car with me sitting in the hatch (cause we swore up and down it was coming from there). Started to take it out a 3rd time, and while doing so I lightly kicked my exhaust tip and it made that clunking/squeaking noise. Turns out, a weld on an exhaust bracket had broken off, causing metal to metal contact. Welded back up and now I'm squeak free
Old Sep 21, 2007 | 10:00 PM
DANSBIRD's Avatar
hmm... this has been happening before i had my exhaust installed... but i'll check that out as well. Thanks!
Old Sep 21, 2007 | 10:33 PM
_JB_'s Avatar
My tail lights squeak. Go lightly pound them and the filler panel and see if they make the noise.
Old Sep 22, 2007 | 04:52 AM
my01ws6's Avatar
Yeah I was about to say my rear hatch rubs on my drivers taillight and squeeks....its soooo annoying....I put a spacer on the taillight to bring it out a little more from the rear hatch...
MY PROBLEM FIXED.
Old Sep 22, 2007 | 08:50 AM
LANDONZ's Avatar
dan, i also had this problem..Is it very high pitched?? Tighten the spare tire up and see if that fixes it !
Old Sep 22, 2007 | 01:57 PM
_JB_'s Avatar
MY PROBLEM FIXED.
Mine squeak where the taillights go into the body. I can't find a permanent solution to fix mine.
Old Sep 22, 2007 | 03:53 PM
redls1bird's Avatar
Do you have stock LCA'S? mine squeak like crazy.
Old Sep 22, 2007 | 04:59 PM
sammyb's Avatar
look for stock lca.s and phb, and the shocks. if the bushings are worn out where they bolt to the body of the car. I had to replace mine and it stopped
