Project "ObseSSed"
Old Jul 6, 2008 | 07:55 PM
  #261
slammed1500's Avatar
Originally Posted by JasonWW
Damn, if it weren't for that master cylinder I'd just chop the top off the fender well and raise it 2 inches. So right now I'm thinking the best thing to do is to see if I can shorten the top of the steering knuckle 2 inches. I've got a specialty welder who might be able to do that. Then I'll just change out the upper shock mount so it's higher. I may get a little fancy and design it so I can adjust my Koni shock from under the hood. The suspension geometry should be pretty much the same as your car. The lower a arm will be traveling higher so I may have to tweak the lower ball joint angle. Did you have to do that?
the spot around the master cylinder is for the upper control arms because i stepped mine
if you use the drop spindles you shouldn't have 2 raise as much as i did
you would mostly have 2 raise 4 the tires
Old Jul 6, 2008 | 08:20 PM
  #262
i have driven the car around some
having a few lil problems with the car running a lil lean
so im trying 2 work that out now
Old Jul 7, 2008 | 02:31 PM
  #263
Beyond Static's Avatar
Post up some progress pics of that "ricer" kenny. haha. rice......
Old Jul 10, 2008 | 01:34 PM
  #264
baylove's Avatar
that thing is crazy low looks good tho
Old Jul 10, 2008 | 02:37 PM
  #265
lowerthanyou00's Avatar
For those interested, I should be recieving some Universal Air front Strut bags to see how they fit on a stock style shock. They are hollow in the middle so fabrication should be minimal compared to Slammed1500's radical reworking in the front.
I should get them today or tommorrow, but it might be a few more days before I can remove one of my shock assemblies to test the fitment around the a-arm and frame. These should be the ticket for folks who already have good shocks on their car like Bilsteins or Konis.
might as well buy a couple of those universal bags, they work for awhile but eventually they start leaking around the band, had the same prob with s10 and xb, changed my s10 to contitech but still replacin bags on xb
Old Jul 10, 2008 | 02:44 PM
  #266
2002Z28Camaro's Avatar
i like how its looks i say thumbs up and great ******* job
Old Jul 10, 2008 | 09:34 PM
  #267
JasonWW's Avatar
We'll see. How much pressure we're you running?
Old Jul 11, 2008 | 09:56 PM
  #268
150-175 on the s10, it weighs alot
the xb runs 100 to 120
all of its half inch but the xb damn near hops
suprisingly not to much pressure compared to what ive seen
sorry slammed1500, nice ride tho, sum excellent work on the front, thatll take a trophy itself
Old Jul 12, 2008 | 05:31 AM
  #269
JasonWW's Avatar
Kenny, are the sleeved bags a good choice for the rear? I hear their softer, but need to be mounted and positioned just right. So I'm thanking a regular RE6 slam bag would be the best overall choice for the rear.
Sound good?
Old Jul 13, 2008 | 11:24 PM
  #270
Jonnybravo55's Avatar
regular bags and a great set o shocks will work fine, course itll ride like **** dumped
Old Jul 13, 2008 | 11:29 PM
  #271
13lu91rS's Avatar
and...
shoulda picked an s10 haha
Old Jul 14, 2008 | 12:26 AM
  #272
JasonWW's Avatar
Since it will be scraping the concrete, I bet it will ride like **** when it's dumped.
Old Jul 15, 2008 | 03:08 PM
  #273
did someone say a s10 on bags?! thats perposterious!!!!!!!!!
gotta tuck ur camaro
Old Jul 21, 2008 | 09:01 AM
  #274
Sound good?
the rearend swings foward a good bet when all the way down
so i think that the double below bags would be better
Old Jul 21, 2008 | 09:33 AM
  #275
a few new pics
ill get a video up soon
Old Jul 21, 2008 | 10:01 AM
  #276
JasonWW's Avatar
Cool, make sure to show the full range of travel.
Old Jul 23, 2008 | 07:46 PM
  #277
o1m6ss's Avatar
Default c
tough crowd.
Old Jul 23, 2008 | 11:13 PM
  #278
JasonWW's Avatar
Hey Kenny, do you think it's possible to do a body drop on these cars?
Now that I think about it, it's pretty similar to what I was considering with raising the engine and drivetrain using a modded K-member and raising the trans tunnel.
Old Jul 24, 2008 | 09:33 PM
  #279
thats pretty much what u have 2 do "unibody drop"
Old Jul 24, 2008 | 10:21 PM
  #280
zdc590's Avatar
That thing looks like a lion or cheetah or something trying to hide in the grass.
I'm not a big fan of what you're doing to the car, but I've gotta say when its done im sure itll be a damn fine show car.
