Project "ObseSSed"
Old Jul 24, 2008 | 10:35 PM
  #281
Black FormulaLs1's Avatar
needs to be triple tuxedo black w/ a cowl hood and an SS spoiler...* f bodies dont have wings*
Old Jul 28, 2008 | 12:18 AM
  #282
JasonWW's Avatar
Did you ever mention the size of your front rim and tire? (kenny)
I think mine stick out more than yours so I may have to cut more along the outside edges.
Did you consider adding some clearance so you could turn the wheels more when your real low? It looks possible except for the area right in front of the vacuum booster. Is that gap needed to be able to replace the booster?
I was toying with the idea of switching it over to a hydroboost setup. It's shorter, but I think it will still hit the A-arm.
I did however come up with a way to have my Koni adjustors accessed from under the hood, but that's top secret.
Old Jul 28, 2008 | 01:34 AM
  #283
JasonWW's Avatar
Here a few "test fit" pictures with the Aerosports and some old stock shocks. Looking good so far.
Old Jul 28, 2008 | 02:41 AM
  #284
sway99bird's Avatar
Looks ****** nice can't wait till you get a video of it rolling down the road throwing some sparks!!!!!!!
Old Jul 28, 2008 | 07:09 AM
  #285
V6Cam's Avatar
I like the looks of this, def. something different which is what i like
Old Jul 28, 2008 | 08:45 PM
  #286
slammed1500's Avatar
the front tire is 245/35/20
yea the booster get a lil tight going in and out
Old Jul 29, 2008 | 05:25 AM
  #287
JasonWW's Avatar
Do you realize you're kept the stock front suspension geometry? Kudo's.
I've just been mapping it out and since your ride height is lower than most folks your getting more negative camber gain under compression as well as more positive camber under extension. That's all good stuff as far as handling goes.
My thoughts about only shorting the top of the spindle, the other hand, would hurt the handling. The only way I'd shorten the spindle is if I can increase the distance from the hub to the lower balljoint by an equal amount and that would be by welding on the spindle.
I think from a cost and safety standpoint I'm going to have to ditch my drop spindle idea and go with your style and notch the upper arms (which is what you actually did).
A bumpster correction kit would be a good idea to minimize toeing in the tires under compression. You want to keep the tie rods parallel to the ground at ride height.
Old Jul 29, 2008 | 05:59 AM
  #288
JasonWW's Avatar
How did you determine how high to move the upper balljoints up?
As much as possible without hitting the hood?
One thing that has always bothered me was the angle of your lower balljoints. Did you tip the top of them inward? It seems like they should be angled slightly outward.
On my setup I'm going to be keeping roughly the same stroke. So I'll be able to go down 2" more than stock and lift up 2" less than stock. I may have to angle both balljoints to make sure they don't bind at either extreme.
I think 2" less of this should be fine.
Old Jul 29, 2008 | 10:09 AM
  #289
the car only needed a 1 1/2" to lay out
so i did every thing 2". i didnt want 2 go 2 mutch because then i would be hitten the hood hinges and the hood
y not jusy buy the drop spindle from the sponsor======>http://www.racecraft.com/proddetail.php?prod=300107
but u will have 2 run a diff. brake setup
i wish that i would have seen that before i did what i did
Old Jul 29, 2008 | 11:12 PM
  #290
JasonWW's Avatar
Besides the extra $550, you have to take a 3rd gen brake rotor and machine it down just to get a hub that you can then slip a 4th gen rotor onto. I worked up a cheap 14" big bake kit with 4 piston Brembo's that bolt onto the stock spindles for $700. I might be able to still use it if I have a custom bracket made. I'm not sure. Plus you lose the ABS.
Or I could just notch the upper arm like you did.
Old Jul 30, 2008 | 01:41 AM
  #291
JasonWW's Avatar
Here's another potential issue for me. I held a mirror to show the tire to spindle clearance.
Moving the wheel 2" higher on the spindle might cause contact. A thin spacer might fix it, but I'm kind of iffy on the whole thing.
A spindle adapter to run 4th gen rotors on a 3rd gen spindle costs $135 pr. So that's $685 were up to plus shipping.
Another unknown is whether the drop spindle plus hub adapter is going to push the wheel out further. A little would be good (so I could clear the upper A-arm) but too much will keep me from tucking the wheels under the fenders.
I really do think modding the upper arms is better for my particular rims and so forth. I'm going to be cutting and welding up there anyway.
Old Jul 30, 2008 | 02:37 AM
  #292
JasonWW's Avatar
Last gen T-birds also use a factory coilover suspension. Here's one with a conventional bag design set up to lay out. Look familiar?
And yes, I own one. A red 97 with a 4.6 as a daily driver.
Old Jul 30, 2008 | 07:37 AM
  #293
i had 2 cut the upper and lower control arms
Old Jul 30, 2008 | 08:34 AM
  #294
JasonWW's Avatar
You say you HAD to cut the lower arm? Why?
Old Jul 30, 2008 | 12:50 PM
  #295
if u change one without the other u change the geometry it
and that rear bushing on the lower control arm can only move so much
Old Jul 30, 2008 | 01:25 PM
  #296
JasonWW's Avatar
if u change one without the other u change the geometry.
I'm pretty sure that's not true. You can reshape the arms all kinds of different ways, but as long as the inner and outer pivot points are in the same location, then the geometry is not changed. All you did up top was make the upper arm dip under the cylinder. There's nothing wrong with that.
Yes, I know about the joints. I'll probably have to tweak the balljoint angles as well as that caster bushing to match their new range of motion.
Old Jul 30, 2008 | 06:23 PM
  #297
bricez28's Avatar
hahah you guys should exchange screen names! to the OP nice work
Old Aug 5, 2008 | 09:39 AM
  #298
i dont think put up a pic of the tank so heres 1
Old Aug 5, 2008 | 09:47 AM
  #299
JasonWW's Avatar
Cool. Who built it and how big is it?
Old Aug 5, 2008 | 10:38 AM
  #300
a local guy that i know
not sure how big it is but it is similar 2 the stock one
