Project "ObseSSed"
Old Aug 21, 2008 | 02:49 AM
  #321
JasonWW's Avatar
Kenny, I was thinking about how to do the rear suspension. Since I'm getting rid of the rear seat, what if I were to make some new lower control arms that were longer, stronger and mounted a little more inboard? It would probably soften the ride as well as give me full up and down movement. I could also play around with the bag size (6 inch to 8 inch) as well as the amount of leverage it has. What do you think of this idea?
Old Aug 21, 2008 | 03:18 AM
  #322
71-Camaro-98's Avatar
Were almost at the 1 year mark for this thread... I think its time to let it go But I do like the car. its clean and original.
Old Aug 21, 2008 | 06:02 AM
  #323
JasonWW's Avatar
Originally Posted by 71-Camaro-98
Were almost at the 1 year mark for this thread... I think its time to let it go.
Go by activity, not age.
Old Aug 21, 2008 | 06:39 AM
  #324
JasonWW's Avatar
BTW, how did you go from this:
To this?
Where did all that extra crap go?
Old Aug 21, 2008 | 07:48 AM
  #325
slammed1500's Avatar
that would be a good way 2 go
rearend wont move front 2 back as going up and down, more travel and better ride
might lose a lil handling performance
but it wouldn't be that hard crosmember from subframe connectors for the front of the bars and then a crossmember fot the top bag mounts
almost wish i would have done this
and use still can use the T/A
To this?
the guy did a **** load of measuring and
the charcoal canister and purge solenoid i put in the wheel well behind the fill neck
Old Aug 21, 2008 | 08:01 AM
  #326
JasonWW's Avatar
OK, I think that's where they were located on the LT1 cars or was it the 3rd gens? One of those.
Do you have any info on what all the lines are for? I haven't figured out each one yet. I need to.
Old Aug 21, 2008 | 10:24 AM
  #327
PhantomR/T's Avatar
looks awesome! Great to see it driving also!
Old Aug 25, 2008 | 02:44 AM
  #328
JasonWW's Avatar
Hey Kenny, I've been having some cool ideas lately. I came up with an idea to keep the stock rear suspension AND add those longer arms to mount the air bag in front of the axle. The key to prevent the new arms from binding the stock suspension is to mount it to the axle with shackles. Since I want to relocate my gas tank anyway, I could even have these 2 new arms behind the axle.
Old Aug 25, 2008 | 10:09 AM
  #329
i dont think a shackle will work
it needs 2 mount like the stock one
Old Aug 25, 2008 | 10:37 AM
  #330
JasonWW's Avatar
Nah, it will work. All it's doing is pulling the axle down.
Or you could weld on a couple links of big chain.
Old Aug 25, 2008 | 11:17 AM
  #331
with the tunnel brace mount T/A like i have
and with a shackle on the LCA's it will allow the rearend 2 move frount 2 back
nothing will be holding it
because the T/A that i have has a shackle on the front of it also
Old Aug 25, 2008 | 11:22 AM
  #332
JasonWW's Avatar
You misunderstand, you keep the stock suspension as is. The stock LCA's stay in place to control front to rear movement.
Old Aug 25, 2008 | 11:56 AM
  #333
i got ya
i would just remove the stock LCA's they r 2 short
thats what pulls the rearend forward when dropped
Old Aug 26, 2008 | 12:58 AM
  #334
The Crazy Sweed's Avatar
Looks good!
Old Aug 26, 2008 | 06:53 AM
  #335
JasonWW's Avatar
Similar to the old C10's.
The are also bolt in ladder bar kits.
Old Aug 27, 2008 | 06:21 AM
  #336
JasonWW's Avatar
This is my definition of cool.
The video is awesome!
http://www.youtube.com/watch?v=GPcsZr8LNl8
Old Aug 27, 2008 | 07:41 AM
  #337
that thing is hovering
bad ***
Old Aug 27, 2008 | 07:54 AM
  #338
JasonWW's Avatar
Can you drive yours that low?
There's got to be a few secrets to it, like good shocks, extra 1/4" manual paddle valves for fine tuning the height, etc...
Old Aug 27, 2008 | 08:03 AM
  #339
JasonWW's Avatar
I'd like to find a small 2-3 gallon plastic tank I can drop my stock sending unit and pump into just so I can move the car around with the stock tank out. Any ideas?
I remember seeing certain new pickups that come without beds or tanks. They are work trucks and later have flatbeds installed. They came with little tanks like I'm talking about so they can be loaded and shipped to dealers. Damned if I know where to find them.
Old Aug 27, 2008 | 08:24 AM
  #340
yes mine will hover
not sure on the tank
