HELP! Wetsanded headlights, cant get it clear again
Old Aug 27, 2008 | 04:26 PM
foreverzero's Avatar
Default HELP! Wetsanded headlights, cant get it clear again
Im currently doing the whislter mod and my headlights were just a little hazy. So I wetsanded them with 1000 grit then 2000 and put on some meguires plastic polish....and now they look worse than they did before...
Old Aug 27, 2008 | 04:43 PM
98hc4mula's Avatar
you have to keep polishing it and putting a lot of elbow grease.
Old Aug 27, 2008 | 05:13 PM
ROCNDAV's Avatar
I just bought and used that 3m kit at autzone. It comes with a foam pad that you put on a drill motor. my results were pretty kick ***. $16 at autozone.
Old Aug 27, 2008 | 05:14 PM
ROCNDAV's Avatar
This guy:
Old Aug 27, 2008 | 05:35 PM
1998LS1SS's Avatar
if you wetsanded it correctly with the 1000-2000 grit and used alot of elbow grease during the polishing stages you should be good...fist time i wetsanded in a circular motion it came out hazzy, try doing it straight across and really polished the **** out of them at the end.
Old Aug 27, 2008 | 05:52 PM
Lotus289's Avatar
You may have to cut a little deeper into the lights. I did my whistler mod a few weeks ago and tried sanding mine down. I only used 800-1000-1500 and they're still foggy. Baby bottom smooth but foggy. The cracks are deeper than what I sanded through. If your are smooth but still fogged I'd say try sanding a little bit more. Then polish them out.
Old Aug 27, 2008 | 06:07 PM
Kingc8r's Avatar
Use elbow grease and the Novus kit from Spadepot.com works great
Old Aug 27, 2008 | 10:14 PM
I just got done putting alot of elbow grease into it. Finally looks good. I just hope the results are permanent, and not just wash off later and look hazy again
Old Aug 28, 2008 | 12:15 AM
samson_420's Avatar
Mine also looked a little hazy. I hit them with ArmorAll. And they are hell of shiny now. It lasted about 2 months so far, yet my car does not leave the garage.
Old Aug 28, 2008 | 12:47 PM
well mine was outside under a carcover and it rained. Hazy again....WTF do I do?!? Im seriously thinking about buying a new set of headlights and leaving them...
Old Aug 28, 2008 | 12:49 PM
Kingc8r's Avatar
here you go
https://ls1tech.com/forums/appearance-detailing/977230-how-fix-dull-headlights-wetsanding.html
Old Aug 28, 2008 | 12:51 PM
Ntimid8r7's Avatar
you can also use the plastic polish that Duragloss or Meguiars makes. Once you sand them with the 2000 the polish will eliminate the haze by "polishing" it out. If you use it everytime you wax the car it keeps them haze free.
*EDIT*
I didnt read into your post enough to see that you used those. The only thing I can say is use a finer grit paper to take out the coursness of what you used before. The 1000 may have been to much. I used 1500 then 2000 and have had no more issues.
Old Aug 28, 2008 | 01:00 PM
Originally Posted by Kingc8r
^ sadly thats exactly what I did...was hazy the next day after I put on maybe 10 coats of wax
Old Aug 28, 2008 | 01:04 PM
*EDIT*
I did use 2000...wait.....i think i actually forgot to use the 2000 grit and used the 1000 twice....whoo hoooo!!!! thats the problem!! Quick question, how long does this typically last until its hazy again?
ROCNDAV's Avatar
That kept happening to me with one pair. I finally got them clear with that 3M kit. check it out, only $16, but you need a drill (I just used a cheap cordless one) to attach the little pad.
Old Aug 28, 2008 | 01:19 PM
Kingc8r's Avatar
You need to go to Spadepot.com bu the Novus 3 step polishing kit. Then polish your head lights. If they are still hazy, go back with a finer grit paper and sand some more.
Then repeat polishing. If still hazy repeat polishing until clear. That's what I did
Old Aug 28, 2008 | 01:21 PM
How long does it last until you have to do it again?
Old Aug 28, 2008 | 01:49 PM
Kingc8r's Avatar
I have heard as long as 2-3 years according to my buddy who did it a while ago....
BTW where did you buy the high grit sand paper? Home Depot, Lowe'sAce, and etc didn't have any....
Old Aug 28, 2008 | 04:35 PM
ArcticZ28's Avatar
The problem here may be that you're "putting on the PlastX". This is not an application like spreading a wax. In order for a polish to work you have to have two things - friction and thus heat. In order to get heat you have to rub quite diligently, not just "put a coat on". If you are doing that, you are just hiding the scratches, which explains why it's hazy again after a couple days.
Do yourself a favor and pick up some 3000 grit and finish with that, then really polish them out with Plastx. I'm talking putting some serious pressure and speed into the rubbing. These things aren't going to disintegrate in your hands by some lame PlastX so don't be afraid.
Old Aug 28, 2008 | 05:32 PM
Counted Out's Avatar
Same problem here. I've polished the **** out of it, but I still see alot of haziness. I'm going to start back with 800, then 1200, then finish it off with 2000.
https://ls1tech.com/forums/showthread.php?t=977050
