s2000 engine start button...
Old Sep 24, 2008 | 03:24 PM
Havok2's Avatar
Default s2000 engine start button...
the link (memberscox.pitre or something) is down, anyone keep it/save it? i thought there was another site, but i cant find it
if anyone save it, post the link, or email me isaac.havok2@gmail.com
Old Sep 24, 2008 | 08:54 PM
1998Z28LOADED's Avatar
The install instructions from this site that "everyone uses" isnt right. They are made to be ran off a computerized circut. Not 12v power wire as described in write-up. My wire ribbon in the button completely fried the first time the car started. Waste of 55 bucks.
Old Sep 24, 2008 | 10:43 PM
Havok2's Avatar
first tiime i hear about this....
Old Sep 24, 2008 | 11:55 PM
01ssreda4's Avatar
switch has to carry a load....yeah that would fry it if not designed for the load.
Old Sep 25, 2008 | 08:44 AM
Havok2's Avatar
ok, if that write up is wrong...
can someone post how its supposed to be wired then?
Old Sep 25, 2008 | 03:08 PM
My friend, who knows so much I cant understand what he's talking about, laughed and said he couldnt believe that anyone made it work that way. He told me what you'd need to make it right but I have no clue what he said, I was already over the idea. He also said it's an ignition fire waiting to happen. So idk... I never heard of anyone else having the problem either.
Old Sep 25, 2008 | 03:48 PM
Havok2's Avatar
i been searching google, import sites install it almost the same that i remember on the write up im speaking off....
Old Sep 25, 2008 | 07:39 PM
I know but the plug is for a computerized circut (look at the plug, its similiar looking to the older hard drive computer plugs). In the s2000 when you hit the button it doesnt power the starter, it tells the computer to start the car. Not meant to become a momentary 12v switch. It may work for some, but from what I experienced and heard not recommended.
Old Sep 25, 2008 | 08:13 PM
InsaneAuto86's Avatar
I have the instructions printed and the s2000 switch installed on my car....
Old Sep 25, 2008 | 08:19 PM
02T/A-WS6's Avatar
hey havoc i think you sent me a message on my youtube(sweet86ss). It does use a small type hardrive type connector as mentioned above. You splice into existing wires under the dash. Basically what happens is you are running a wire from a 12v source and to the relay, to the button, to the starter wire. I cant remember the diagram off hand.
I remember a 30 or 40 amp relay is the one to use.
On the back of the button there are only three wires goin to it( two wires to complete the circuit and one for ground I believe.
If people had burning up problems then the wiring must have been incorrect.
Old Sep 25, 2008 | 08:39 PM
LS1Zedder's Avatar
I installed mine as per those same instructions 5 years ago and had no problems.
Old Sep 25, 2008 | 10:15 PM
98 WS6's Avatar
Anyone got pics of this in the car?
Old Sep 25, 2008 | 10:17 PM
01ssreda4's Avatar
+1 sucka
Old Sep 25, 2008 | 10:20 PM
98 WS6's Avatar
Old Sep 26, 2008 | 06:48 AM
Back when I had the LS1 center console...
Old Sep 26, 2008 | 07:23 AM
Big Bird WS6's Avatar
to bad we can't set it up to work like the new vete. just keep that little fob in my pocket. no key. and just start and go.
Old Sep 26, 2008 | 08:54 AM
VIP1's Avatar
Copy & Paste Moderator
Anyone think of searching the site you are on.....
https://ls1tech.com/forums/appearance-detailing/658849-push-start-button.html
https://ls1tech.com/forums/wiring-stereo-electronics/680997-push-button-start.html
https://ls1tech.com/forums/appearance-detailing/885086-finished-up-my-interior-upgrades-pics.html
https://ls1tech.com/forums/wiring-stereo-electronics/847751-push-button-ignition.html
I just searched for "start button". Not all the links in those threads work anymore, but it looks like at least one did. There is still plenty of good info in those threads (technical and diagrams).
I found a link that works...
http://www.bowlingss.com/Mods/Instal...e%20Switch.mht
It was in one of the above threads. That page seems to only work in Internet Explorer though.
BTW, the link you were thinking of is:
http://members.***.net/pitre/s2000sw.htm
Which moved to:
http://www.pitreweb.com/s2000sw.htm
But neither works anymore.
Old Sep 26, 2008 | 08:59 AM
VIP1's Avatar
I think you forgot a relay. That switch can't handle the full load of the ignition system. It's intended to switch a relay which will switch the ignition system.
Old Sep 26, 2008 | 09:34 AM
and not to sound like dumb ***. but is it possible to not have to put key in the car. like the new vetes do?
Old Sep 26, 2008 | 09:57 AM
Havok2's Avatar
that requeires a diff system..not just a push button start...
VIP: your awesome! thanks, thats what i needed!! i did do a search, but just a lot of mumbo jumbo, no diagram that i could read/comprehend LOL but thanks!
