More 4L60E Problems
Old Oct 13, 2008 | 01:06 AM
G:342's Avatar
Default More 4L60E Problems
First transmission that was in the car blew the 3rd/4th clutch pack and was useless, so I bought a rebuilt one and had it installed, Worked just great until friday night.
I pulled into a gas station and grabbed some 93, pulled out and it went from 1st gear directly to 3rd and then wouldn't go into 4th at all. In 3rd I was doing 55mph and it was shaking violently like the damned thing was going to fall out. If you shut the car off and leave it parked for about 5 minutes, the first time you drive it, it will shift into 2nd and then into 3rd and then it will leave it in 3rd gear and not downshift at all. Unless you manually shift it back to first it will force you to leave a dead stop in 3rd. Anyone have a clue? I've got a warranty on the Transmission.. The car is a 1996 Trans Am.
Old Oct 13, 2008 | 12:48 PM
G:342's Avatar
Anyone?
Old Oct 13, 2008 | 01:00 PM
TXZ28LS1's Avatar
man sorry to hear that!! honestly, i would give our sponsors a call for sure. either FLT, ACE, performabuilt. i know u have a warranty, but honestly i would go ahead and spend the money on getting the tranny rebuilt the right way by guys that know these trannies. i would hate to see u use your warranty, and the same thing happens over and over again. just give our sponsors a shout.
Old Oct 13, 2008 | 01:03 PM
the_merv's Avatar
When you shut the car off it reset's everything in the Tranny and it will shift right until it hits the problem again. Sounds like it's in a default/limp mode, that's what they do when it's in that. More than likely something came loose inside. I would send it back.
My last Transmisson lost 3 & 4 when the Snap Ring came loose, and all I had was 1 & 2. I managed to drive it till the Band heated up and I had no 2nd no more. I was about 5 miles from the Shop, so when it would stop pulling, I would shut it down fo a few seconds to reset, then start it back up and it would move again for a little bit. I did that till I got back to the Shop, then parked it.
Now you know why it says T56 coming in my sig..
Old Oct 13, 2008 | 01:10 PM
G:342's Avatar
That's what I'm planning on doing to be honest with you, I'd just like to know a bit more specifically on what's going wrong, if this has happened to anyone else, etc. It's just money is a bit tight after paying for college so. Either that or just do a T56 Conversion if I can find a good deal.
Old Oct 13, 2008 | 01:23 PM
performabuilt's Avatar
LS1Tech Sponsor
Are you getting and SES light what your describing is limp mode if so youneed to scann and see what the code is it may be a simple electricl issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 13, 2008 | 01:26 PM
G:342's Avatar
No SES light.
Old Oct 13, 2008 | 01:30 PM
the_merv's Avatar
Get a scanner on it and see what codes it's throwing in the Transmisson.
That's why I'm doing mine.. can't have any electrical issues with Gears..
Old Oct 13, 2008 | 03:05 PM
G:342's Avatar
Going to get it scanned tomorrow and see what it's throwing.
I've been wanting to sell it actually, but I didn't want to until I knew everything was in 100% Working order. I don't wanna pass any problems onto the new owner. It pays to be honest though.
Old Oct 13, 2008 | 03:44 PM
the_merv's Avatar
Yea it does. Kharma's a bitch..
Old Oct 15, 2008 | 10:10 AM
G:342's Avatar
Got it scanned yesterday and It turns out to be the 3-2 Shift Solenoid is bad.
Old Oct 15, 2008 | 11:01 AM
LS1Tech Sponsor
Easy Fix Anyway
__________________
Call 888-744-6542
Old Oct 15, 2008 | 02:34 PM
omcar's Avatar
If you have a loose converter the solenoid may not be bad..it may be the computer program sensing the slip and putting you in "limp" mode..happenned to me ( I replaced the solenoids twice before figuring it out)..get the trans codes deleted.
Old Oct 15, 2008 | 03:16 PM
LS1Tech Sponsor
True the shift solenoids 1-2 and 2-3 PO757 and PO751 do need to be removed the 3-2 solenoid only sets a code for and electrical fault so I would have to say in its case it is actually a bad solenoid either shorted or open
__________________
Call 888-744-6542
Old Oct 16, 2008 | 04:47 PM
G:342's Avatar
Dropped the Trans today and that's what it was, the solenoid was floating around. Thanks for the advice everyone!
